Interested in ECU tune for the ISF ?
Old 03-08-13, 02:27 PM
  #31
aWorkOfArt
aWorkOfArt's Avatar
Thumbs up
Originally Posted by Jeff Lange
Japan doesn't use octane that is much higher than we do. Japan's RON 96 High Octane is roughly equivalent to the AKI 92 Premium Octane sold in North America.
Jeff
If what you stated is true. I hope they are able to tune our USDM ECUs!
aWorkOfArt is offline
Old 03-08-13, 02:39 PM
  #32
ISF4life
ISF4life's Avatar
They r doing it now
ISF4life is offline
Old 03-08-13, 09:08 PM
  #33
SuprFleaJQ
SuprFleaJQ's Avatar
need to see it fully functioning on a US-spec car!! If everything checks out, count me in!
SuprFleaJQ is offline
Old 03-08-13, 09:12 PM
  #34
96817isf
96817isf's Avatar
seen it on fb and im deff in on this buy count me in on this when its available just lmk when
96817isf is offline
Old 03-09-13, 12:15 AM
  #35
JDMV8
JDMV8's Avatar
count me in too,
not crazy about sending away the ecu though, rather keep it within the states--mainly for convenience dealing w/warranty issues;
a modified ecu will compromise most warranty claims :/
JDMV8 is offline
Old 03-09-13, 04:15 AM
  #36
ming15237
ming15237's Avatar
Default Ecu
Originally Posted by JDMV8
count me in too,
If this really were to work, why not just buy a salvage yard ecu, and send it to them to be re-flashed. All you would need to do is send them your vin number in that case and they could flash it with the appropriate information, and their tune...
ming15237 is offline
Old 03-09-13, 05:21 AM
  #37
kauaian
kauaian's Avatar
Jeff
Yes, Japan measures by Ron whereas the US uses Ron + Mon / 2.
A 95 Ron octane rating is the equivalent to 92 in the US.
( RON Octane Rating x 0.95 = AKI Octane Rating )
98 RON Octane x 0.95 = 93.1 AKI Octane (US measure)
100 RON Octane x 0.95 = 95 AKI Octane (US measure)
So it's a little higher than what we have available in the US. Either way maps won't be on point so we need someone local to properly tune.
kauaian is offline
Old 03-09-13, 07:46 AM
  #38
Lexura1414
Lexura1414's Avatar
Nigel, please send me a qoute via PM re this tune. Am interested
Lexura1414 is offline
Old 03-09-13, 09:15 AM
  #39
JDMV8
JDMV8's Avatar
sure, this seems like the only viable option. not necessarily a junkyard ecu, but a secondary one
JDMV8 is offline
Old 03-09-13, 07:35 PM
  #40
IsFactor
IsFactor's Avatar
Subscribed! Very anxious to see results
IsFactor is offline
Old 03-09-13, 07:48 PM
  #41
NotnFsport
NotnFsport's Avatar
we have been waiting a long time so waiting a little more wont hurt my issue is that yes u can send your ecu to them but i strongly advise against that. too many variables. is the F they are utilizing stock? just intake? just exhaust? headers? etc etc. u might get a tune for a stock isf running on 97 octane. yes youll see gains on paper but lets say your f has i/h/e i seriously doubt youll see the gains. we need the tuner hardware and car on the dyno to specifically tune for what u have. if they have 4 Fs. one stock.one with intake,one with i/e and one with i/h/e and u get to choose lets say 93 octane....id say go for it ...send out your ecu .but they dont...just my 2 cents
NotnFsport is offline
Old 03-09-13, 07:53 PM
  #42
CarbonISF
CarbonISF's Avatar
I guess the counter point to amgone would be if we have a wide band sensor the ecu would adjust to any higher flowing exhaust mods. I'm not sure if we have a wide band or not... A 92 octane tune works for me.
CarbonISF is offline
Old 03-09-13, 08:31 PM
  #43
Supraman16
Supraman16's Avatar
interested. subscribed...
Supraman16 is offline
Old 03-10-13, 08:48 PM
  #44
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
The primary O2 sensor for each cylinder bank is a wideband planar sensor. The secondary is NB.
It may be possible to have some serious problems if you purchase a junkyard ECM, have it flashed, and then install it. I would not want to be the guinea pig for doing it this way. The key security system is certificate based, and there is a sequence of exchanges that happen between the certification ECU and the ECM before the engine will start. Because of this, it might be necessary to have the "new" ECM installed in the car and registered with the certification ECU for the smart key to work.
I am not 100% certain, but again, I wouldn't want to find out the hard way unless I was prepared to have a Techstream security specialist on hand to make sure nothing goes wrong.
So - update - swapping ECMs (not removing and reinstalling the same unit) means you'll need to initialize the TCM, throttlebody, and write the correct VIN to the ECM. Toyota tech data is very clear this must be done with Techstream. Also, there is a procedure for initializing the ID Code ECU which is the thing generating the immobilization code to prevent theft. This procedure requires you to turn the car on without starting the engine with CG and TC pins in the DLC shorted for 30 minutes. If you don't do this, the engine won't start.
lobuxracer is offline
Old 03-11-13, 06:16 AM
  #45
CarbonISF
CarbonISF's Avatar
Ah, good to know, thanks lobux.
Regarding the ECU swap, on the newer Genesis Coupe, they count the mileage in two places, on the dash and in the ECU. So they really have no options but to tune the ECU and leave all the dealer scannable diagnostic parameters in place so it isn't a huge red flag for warranty work. Wouldn't surprise me if our cars do the same.
Quick Reply: Interested in ECU tune for the ISF ?
