VSC Light after installing HPS tube & AFE wet filter
Old 02-26-13, 10:44 AM
Jkru2000
Jkru2000's Avatar
Default VSC Light after installing HPS tube & AFE wet filter
I installed the HPS intake in my 08 isf a week prior to swapping the air filter. After 3 days running both? on my way in to work the vsc and check engine came on. I tried the reset (holding vsc and pushing the start button twice w/o the brake). But no help. I will replace back to stock and let you know after. Any ideas on what may be causing this? I read something about the oil from the wet filter possibly causing problems with the maf?
Old 02-26-13, 11:17 AM
zapa
zapa's Avatar
Yes my guess is that it is the oil clogging up the MAF. If i were you I would keep the HPS pipe, clean the MAF sensor, and get a non oiled filter.
Old 02-26-13, 11:18 AM
2ndGF
2ndGF's Avatar
This just happened to someone else about 2 weeks ago - go non-oiled
Old 02-26-13, 12:01 PM
vmatheboss
vmatheboss's Avatar
I got afe dry filter with hps too, mine never has problems
Old 02-26-13, 12:05 PM
digger08
digger08's Avatar
I would also check the permanent filter media/ restrictor baffle thing inside of the housing and ensure it did not soak up oil as well.
Digger08
Old 02-26-13, 12:16 PM
Jkru2000
Jkru2000's Avatar
From what I read, I thought was supposed to be the best combo, Looks like I will need to go dry. Any idea on how to clean oil off the permanent media filter baffle thing? Shame on me, I thought everybody said go wet?
Old 02-26-13, 12:17 PM
ShadowISF
ShadowISF's Avatar
I had a dry filter before and never had problems with it.
Old 02-26-13, 01:09 PM
digger08
digger08's Avatar
hmm....not sure, check it first as there may be nothing to worry about.
Digger08
Old 02-26-13, 01:48 PM
Boma
Boma's Avatar
I've had the Joe Z intake and the aFe dry filter for several miles. Now I have an HPS intake with the same aFe filter. No problems whatsoever!
Oiled filters may have been advertised to offer better performance, but with it being in close proximity to the MAF sensor it would probably cause problems if oil is flung into it.
Someone here conducted a test seeing if the air filters made any difference in the performance of the F. He ran with a filter and without a filter and found out that he got the same numbers regardless.
Old 02-26-13, 02:23 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
^^ And that is why a run an CLEAN OEM Filter every 25k miles or soo....
~ Joe Z
Old 02-26-13, 02:43 PM
Jkru2000
Jkru2000's Avatar
Sounds like the oiled filter is the culprit, I'll give an update after I get done cleaning out the maf and replacing the filter.
Old 02-26-13, 03:01 PM
aWorkOfArt
aWorkOfArt's Avatar
Dry filters FTW. Im running an AFe Pro Dry and a JoeZ Intake. 4000mi in with no issues. Hopefully you get everything worked out. Good Luck Bro!
Old 02-26-13, 03:03 PM
Joe Z
Joe Z's Avatar
Lightbulb
Old 02-26-13, 04:12 PM
KOKISF
KOKISF's Avatar
i would recomend scaning the car obd2 for codes , its probably something else
Old 02-26-13, 06:05 PM
Jkru2000
Jkru2000's Avatar
Just got some of the crc. Scanned and got running lean code and possible maf code, Thinking its got to be oil on the maf. Thanks for the advice so far guys.
Quick Reply: VSC Light after installing HPS tube & AFE wet filter
