Joined the LED headlight club
Old 02-14-13, 12:28 PM
CalitriSC
CalitriSC's Avatar
Default Joined the LED headlight club
Well I have liked the new headlights since they first came out. I was finally able to get a good deal on a set and put them on last night. They really update the front end and are a nice upgrade. I have the LEDs wired at 100% brightness. Some pics.....
Old 02-14-13, 12:30 PM
jdm_altzza
jdm_altzza's Avatar
did you have to trim your brackets? The reason i ask is because i didn't have to modify them at all. Great lights btw, hope you enjoy them like i do lol..
Old 02-14-13, 12:39 PM
CalitriSC
CalitriSC's Avatar
Yes I had to trim the brackets to work with the new headlights. Thanks!
Old 02-14-13, 12:42 PM
vrmRollLex
vrmRollLex's Avatar
looking good man! I want to also get these. where did you get yours from? (I should've bought them when sewell was having that deal a while back)
Old 02-14-13, 12:45 PM
CalitriSC
CalitriSC's Avatar
Thanks, I got them on here in the classifieds for $900
Old 02-14-13, 01:04 PM
obby
obby's Avatar
this mod is a must for all earlier years.. lol.. looks good bro.
Old 02-14-13, 01:11 PM
atl08isf
atl08isf's Avatar
looks really good, I hope to do this upgrade soon
Old 02-14-13, 01:15 PM
Vroomin350
Vroomin350's Avatar
Looks good, definitely makes the front end much more aggresive. For anyone looking for a set there is one on Ebay selling for $672 shipped
Old 02-14-13, 01:18 PM
CCColtsicehockey
CCColtsicehockey's Avatar
I love the black chrome headlights. They definitely do make the car look more aggressive.
Old 02-14-13, 01:24 PM
digger08
digger08's Avatar
For my 2008 MY, I had my lights replaced under warranty in 2011, they used the newer brackets...this would explain the differences...sometimes.
Digger08
Old 02-14-13, 02:02 PM
jdm_altzza
jdm_altzza's Avatar
Digger08
It could be.. but then again the IS-F brackets are different than the ISX50. Therefore i dont think anybody has even bothered to test fit the is-f brackets (w.o modifying them) & installing the bumper on the car to see where the issues is...
When i installed my lights i wanted to check where the main issue was before i started to make my cuts and not mess the brackets up. Then i realized i didn't have to cut anything. if you see my post below you will see the brackets were not even touched, although i was only able to mount 2 screws.
https://www.clublexus.com/forums/is-...tion-help.html
This is the same issue others run with the 2012 LED tails. some say you have to cut/bend tabs, while i didn't modify/cut tabs on the lamps when i had my 08 is250. Now with the IS-F i installed the rear lights once again without braking any tabs or any type of modification.
Old 02-14-13, 02:18 PM
1sWt2GS
1sWt2GS's Avatar
looking good, is this a direct swap?
Old 02-14-13, 02:42 PM
Vroomin350
Vroomin350's Avatar
Actually I did, and the issue lies in that the ISF brackets stick out further than the ISx50. Most likely for the extra support needed on the heavier/longer bumper of the ISF.
As for the trunk, the only people who will have to modify for a flush fitment of the 2009+ taillights, are 06/07 cars. Everyone else will not need to do anything for the taillights.
Old 02-14-13, 02:44 PM
LexusNN
LexusNN's Avatar
Looks great!! So much better and more aggressive
Old 02-14-13, 02:45 PM
JDMV8
JDMV8's Avatar
I believe the listing you're referring to is only for one headlight.
The seller does not make it too clear.
Quick Reply: Joined the LED headlight club
