New 1/4 Mile Record
Old 02-03-13, 08:08 PM
  #76
ToothDoc
11 Second Club
ToothDoc's Avatar
Originally Posted by 2URGSE
Nice reaction time!! (60 ft)
60' time isn't reaction time - it's literally the first 60 feet AFTER he trips the start so that has nothing to do with reaction time.
Old 02-11-13, 02:08 PM
  #77
Juanca
Juanca's Avatar
Let's see if I can explain this: since I got my first ISF (early 2008), I've been driving in sport, VSC off, and manual mode all the time. When moving from a stop/red light at moderate throttle on the 2008, the car will just jump forward quickly, at full throttle I'd spin the tires (tire) pretty bad. On the 2012, moderate throttle from a stop/red light would be hesitation for a tiny fraction of a second, then the car would jump forward progressively (not as abrupt as the 2008). Full throttle would be spinning the tires as bad as with the 2008, but again I'd have the same hesitation for a fraction of a second. Initially I thought that the hesitation was the tires but no, they're not spinning, it's the tranny "engaging" something (I guess a gear). You might not notice it unless you compare times at the track. I have a local 1/8th mile track that I use for comparison because I've been there plenty of times. Even though the track sucks, it's bad prepped and uneven, it serves its purpose for this comparison. My bone stock 2008 was hitting 8.5s, and after JoeZ intake and muffler/cat delete it was hitting 8.3s, always on 20" wheels. My 2012 on the same 20" wheels hit 8.8s bone stock, and 8.5s after JoeZ intake, PPE headers, and ISS Forged DES exhaust. My trap time is slightly higher on the 2012, which means that I have more HP than in the 2008, but my times are not. I may go faster once I'm rolling, but off the line I suck!!!
Originally Posted by ToothDoc
As long as you're not spinning, whether you have LSD or not doesn't matter. If you're spinning one wheel, then LSD will help. I don't have enough HP to spin so whether I go LSD or not doesn't make any difference in my 60'. Maybe in Juanca's case, the new 2012 has a slight revision of the TCU to allow a little bit of slip to protect the transmission?
Old 02-11-13, 05:38 PM
  #78
darbs242
darbs242's Avatar
I can not understand how the 2012 seem to be slower off the line. They should hook up much better and having the same motor and transmission.... Why are the times different? Anyone have any thoughts
REDHORSE
LX - 3rd Gen (2008-2021)
03-31-19 06:56 PM
norcal2jz
13
10-30-11 04:22 PM
SocalMr2
04-28-11 02:13 PM
Quick Reply: New 1/4 Mile Record
