255-35-r19
Old 01-27-13, 12:38 AM
ktb
ktb's Avatar
Default 255-35-r19
Anybody running on 255-35-R19 on after market wheels in the front plus lowered on springs.
How's turn out any rubbing issue?
Old 01-27-13, 02:21 AM
ISF4life
ISF4life's Avatar
Slightly turn is not going to rub but if u do full turn , it will rub the inner liners inside , because the width is wider. Other then that u r fine. 245 to be ideal .
Old 01-27-13, 07:09 AM
rapsquared
rapsquared's Avatar
all depends on the offset of your aftermarket wheels
Old 01-27-13, 09:16 AM
Fivepoint0
Fivepoint0's Avatar
Also depends on the tire brand because some tires run big. Currently have 255 35 Michelin pss on 8.5 wheel with a 30mm offset lowered on tein springs
It rub slightly . 245 or 235 would be best
Old 01-27-13, 04:59 PM
SaintLexus
SaintLexus's Avatar
I'm running 255 35 19s on stock rims and they only rub when I'm backing up. I have 275 35 19 on the rear.
Let me add... I have stock suspensions and springs.
Old 01-27-13, 07:01 PM
Rossi
Rossi's Avatar
Can you please post some photos?
Old 01-27-13, 10:41 PM
CalitriSC
CalitriSC's Avatar
I had 255/35/19 up front with my last set of wheels and it was fine.
Old 01-27-13, 10:54 PM
shyguyF
shyguyF's Avatar
I'm running 255/35r19 bs potenza re050a on 19x9 et38 and lowered on swift spring no rubbing at all.
Old 01-27-13, 11:08 PM
ktb
ktb's Avatar
Thanks guy for the info.
255 / 35 / r19 on 19x9.5 +19 lowered on Swift spring.
Old 01-27-13, 11:24 PM
shyguyF
shyguyF's Avatar
You're 26mm stick out compared to mine, very aggressive looks.
Old 01-27-13, 11:27 PM
bnizzle87
bnizzle87's Avatar
That's pretty aggressive. I'm not entirely positive, but you'll probably need some fender work done. 255/35's do fit in the front, as I've seen other members upsize to that, but I'm not sure about the offsets.
Old 01-28-13, 05:53 AM
darbs242
darbs242's Avatar
255/35/19 AD08's rub every so slightly on full turn in... Strasse custom offsets... but i am on swift springs. i dont think being dropped will matter as it only rubs on full turn in on the liner. Im switching my rears when there done too AD08 in 295/30/19 from my 275 nitto nt05
Old 01-30-13, 05:23 PM
SaintLexus
SaintLexus's Avatar
Here's one shot. Sorry it took so long for me to reply. Hope this works. if not just click on this link to take you to my flickr account. http://www.flickr.com/photos/2734635...6955/lightbox/
Rohi123
IS F (2008-2014)
12
02-28-16 07:03 PM
joeyfett
11-06-12 04:38 PM
IS350HKS
11-06-10 03:49 PM
DeviousOne
05-29-09 11:55 AM
lowKut
02-17-09 08:50 PM
Quick Reply: 255-35-r19
