IS-F Centre Dash Speaker
Old 01-01-13, 07:48 PM
Reyes1
Reyes1's Avatar
I took the Speaker out, it looks just like yours! The part is like a little Bottle Cap that just needs to be glued back on top of the Cone. But I can't get to it without taking the Membrane off. Has anybody taken one of these apart? Is there a way to remove the Membrane without having to rip it out?
Old 01-01-13, 08:25 PM
Reyes1
Reyes1's Avatar
Ok, so I removed the Speaker held by two 10mm Bolts. Peeled half of the fabric that covers the speaker and sure enough, what appears to be a Dust Cap, had come loose and was causing the noise. Glued it back in place, put the Speaker back in and the problem was solved, no more noise!
Old 01-02-13, 04:22 AM
jdm_altzza
jdm_altzza's Avatar
^^^^hahahaha good man.... i just glued it last night and will put it on today. i will keep you updated.
Old 01-03-13, 04:43 PM
jdm_altzza
jdm_altzza's Avatar
Update... glued the top on the speaker and it sounds brand new. Thanks to all that helped and hopefully this will help someone else with the same issue in the near future!
Old 01-03-13, 05:06 PM
kauaian
kauaian's Avatar
Glad to know it was a simple and low cost fix!
Old 01-03-13, 09:04 PM
DS2k
DS2k's Avatar
Great news! I'm so glad I decided to check CL today! I have a similar issue and I hope it's as an easy fix as this
Old 09-19-14, 05:42 PM
786's Avatar
thanks to this thread i just resolved the same issue on my car.
just super glued the cone back on!
Old 09-20-14, 05:19 AM
jdm_altzza
jdm_altzza's Avatar
Great!!
Old 09-20-14, 05:34 AM
ICEBERGS
ICEBERGS's Avatar
You can do what I did and take a razor and cut open that lil foam grill and just take that little cap off instead of gluing it back...sounds no different with it on or off..horrible design..save that 180 dollars for something else
Old 09-21-14, 01:46 AM
dannyk8232
dannyk8232's Avatar
Lex dealer wanted $180 for that little tweeter????
Old 09-21-14, 04:17 AM
Rickna
Rickna's Avatar
The cap is just a dust cap to prevent dust from getting in the voice coil. It will work fine without it.
Old 09-21-14, 06:39 AM
786's Avatar
Super gluing it took 10 seconds, why would you remove it lol
Old 10-28-15, 04:53 PM
Twotwo
Twotwo's Avatar
Thanks I gotta u plug mines
Old 10-28-15, 07:03 PM
Twotwo
Twotwo's Avatar
Easy fix o just had to glue it back
Just glue it.. So easy
Easy to take off just use a credit card and then take off 2 10mm bolts
Quadrphnia (03-25-22)
Old 10-30-15, 05:07 AM
ping83
ping83's Avatar
Mine had the exact same issue. Removed the felt, superglued the piece that was loose back in place and reassembled, problem solved!
Quick Reply: IS-F Centre Dash Speaker
