Question about offsets on the IS-F rims
Old 12-28-12, 09:31 AM
Hameed
EV ftw!!!
Hameed's Avatar
Default Question about offsets on the IS-F rims
1. What are the offsets on the stock IS-F rims?
2. Has anyone put on wider tires on the stock IS-F rims? Specifically would 245's fit the fronts and 275's the rears?
There are a couple of sets of IS-F rims on sale in the classified wheels and tire sections and I'm considering swapping out my 18 inch HRE's for them. I have the StopTech BBK, and considering that the IS-F comes with a Brembo BBK, I'm assuming they would clear mine.
My current wheels offsets are 31 and 37 and are high disk - https://www.clublexus.com/forums/780210-post195.html
Old 12-28-12, 09:40 AM
bnizzle87
bnizzle87's Avatar
1. For the '08-'11 model wheels, it's 19x8 +45 front and 19x9+55 rear. For the '12 model wheel, it is 19x8.5 +45 and 19x9.5 +55.
2. There have been many members running wider tires on the stock wheel. Many go with the setup you're looking for with the 245/275 combo, but I know a few members that are going 285, which they all have said safely fits with the '08-'11 wheel choices.
Hope this helps!
Old 12-28-12, 09:52 AM
caveman
caveman's Avatar
2012 rear offset is actually 51mm
2012 19x8.5 F 45MM
2012 19.9.5 R 51MM
See post #124 here:
https://www.clublexus.com/forums/is-...eleases-9.html
Old 12-28-12, 09:58 AM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
Complete Wheel Specs are attached.
Lou
YeShrug (07-09-19)
Old 12-28-12, 10:00 AM
CalitriSC
CalitriSC's Avatar
What kind of big brakes do you have? Because they clear stock F brakes yes, but that doesn't mean they will clear other big brakes. ISF wheels don't even clear IS 350 brakes without a spacer. Or stock LS 400 brakes, I know because I tried.
Old 12-28-12, 11:37 AM
Hameed
EV ftw!!!
Hameed's Avatar
I have the StopTech BBK.
Old 12-28-12, 01:40 PM
CalitriSC
CalitriSC's Avatar
Oh sorry didn't see that. I would test fit in the front before buying a set.
Old 12-28-12, 04:00 PM
Meraki Autoworks
Your #1 Lexus Vendor
CL Vendor - Starter
Meraki Autoworks's Avatar
What's the fattest tires someone's put on a stock 2011 wheel?
Old 12-28-12, 07:25 PM
flowrider
flowrider's Avatar
^^^^I believe my F has the widest tires that will fit on a stock (2008-2011) ISF wheels;
https://www.clublexus.com/forums/is-...-position.html
Lou
Old 12-28-12, 08:00 PM
Hameed
EV ftw!!!
Hameed's Avatar
So the only question is whether the rims will clear the StopTech BBK or not.
Old 12-29-12, 12:17 AM
SaintLexus
SaintLexus's Avatar
I have wider tires on my stock IS-F 2008 rims. I have 255/35/19 on the front and 275/35/19 for the rear. This is basically my current set-up right now. Check out the picture.
or click here to take you to my flickr account http://www.flickr.com/photos/2734635...oto_8294939996
Next time I'd go for 285/35/19 for the Rear!
breezie3
IS F (2008-2014)
12
11-22-16 02:35 PM
IS250JAZZ
03-21-13 10:04 PM
SamChuang
02-24-13 07:51 PM
iChiBahN
IS F (2008-2014)
03-20-08 11:41 PM
Quick Reply: Question about offsets on the IS-F rims
