Will I fail car inspection if AFS light is blinking?
Old 12-14-12, 09:37 AM
FastPaced
FastPaced's Avatar
Default Will I fail car inspection if AFS light is blinking?
As title says. Sorry for these sudden threads/post, I just got my car back from the body shop where it was for a month and my inspection is expired. So I'm trying to handle so many things at once.
Old 12-14-12, 10:57 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Lightbulb
You can pull the AFS - Auto Leveling Fuse found on the drivers side small fuse box above the foot rest...
AFS light will stop flashing...
However, headlights will no longer Auto Level up and/or down..
~ Joe Z
Old 12-14-12, 12:48 PM
zapa
zapa's Avatar
^^^^isnt that kinda cheating the inspection??
Old 12-14-12, 01:15 PM
kauaian
kauaian's Avatar
I don't know if AFS generates a code or not but wouldn't that be the ultimate factor? Thats if your inspection requires a OBD scanner to be hooked up.
Old 12-14-12, 01:39 PM
Boma
Boma's Avatar
You probably won't fail. I've had my beater car with a check engine light pass inspection with no problem year after year. (cel was from an aftermarket intake) I don't think the inspector would be worried about afs not working so as long as all your lights are working I wouldn't worry about failing.
Old 12-14-12, 01:41 PM
Joe Z
Joe Z's Avatar
Lightbulb FYI for All...
"Cheating" ??
If he updated his headlights to the 2011 Lamps with LED's... Then he has a flashing AFS light..
AFS stands for "Adapative Front lighting System"... The AFS ecu is looking for two AFS swivel motors that bascially are now not there...
Plus, all of this shouldn't really apply to the "inspection".. However, NO light is always better than a flashing indicator light...
~ Joe Z
Old 12-14-12, 01:52 PM
ISF4life
ISF4life's Avatar
Just put the small black tape infront of it or like Joez says pull out the bottom fuse just for that day
Old 12-14-12, 02:25 PM
staman
staman's Avatar
I got an AFS cel after I changed my rims. My ride height changed thus throwing off the sensor. I adjusted it from under the hood, or you can just put and OBDII scanner on it and delete the codes.
Old 12-14-12, 02:34 PM
Joe Z
Joe Z's Avatar
Lightbulb
That wont work for him... Be cause he installed :
2012 LED Headlights from Sewell. High Beam Dilemma.
~ Joe Z
Old 12-14-12, 04:16 PM
streetx
streetx's Avatar
no you will not fail
Old 12-15-12, 11:13 AM
staman
staman's Avatar
~ Joe Z
Thats why i mentioned the obdii
Old 12-15-12, 12:32 PM
Mortis101
Mortis101's Avatar
I just finished pulling my cluster out and used some electrical tape to cover the light.
Took about 20 minutes and no more AFS blinking. I didn't want to lose my auto leveling feature.
OzzieISF
IS F (2008-2014)
15
06-25-18 11:46 AM
2istype
12-22-17 04:54 AM
lanthern22
GS - 1st Gen (1993-1997)
02-03-09 03:07 PM
boosst
04-20-07 07:24 PM
diamondlex
11-02-06 09:43 PM
Quick Reply: Will I fail car inspection if AFS light is blinking?
