DIY LED 'stripped' headlight installation
Old 08-10-14, 01:05 PM
  #61
MK4Sup_isF
MK4Sup_isF's Avatar
Originally Posted by MEAHT
Thanks for the quick reply MK4Sup_isF.
Would I be able to buy this part used and still be able to use an aftermarket hid kit?
Found some on ebay for $60 each.
thanks
Do you mean aftermarket hid bulbs? If so, then yes. I recommend something like Garax HID bulbs if you don't want to spend more on Phillips 5000k or 6000k bulbs. I put Garax on my ex's SC430 6 years back and they are still running fine. The Garax on my car are about 2 years old now. Quality is very good and they are made in Japan.
Old 08-10-14, 02:09 PM
  #62
MEAHT
MEAHT's Avatar
You the man.
Thanks for the help
now to wait another week for 2 ballasts to come in the mail :/
Old 04-26-15, 02:37 AM
  #63
LexoticJ
LexoticJ's Avatar
Originally Posted by digger08
Probably...several pins are moved on the Sewell lights friom the factory orientation, to ensure they plug and play. That's the advantage of ordering from them
Digger08
I bought these headlights off a friend... how do I connect them to my 2007 lexus is250
Old 04-26-15, 07:37 AM
  #64
Sean
Sean's Avatar
^ This thread should tell you everything you need to know as far as removing the old and installing your new lights.
https://www.clublexus.com/forums/is-...on-how-to.html
That is mainly for installing the Sewell rewired lights. If you need to repin, or if you want to wire the LEDs to always be on or dim to 50% with low beams, there are threads discussing that also. Search it up.
Old 07-20-15, 12:59 PM
  #65
STLblueF
STLblueF's Avatar
So maybe I'm missing something but if the leds come on with the parking lights from the way Sewell wires them, why would I need to pull out the red wire and ground it? Wouldn't that already be grounded? I understand wiring the green wire to the fuse tap, but the ground seems like a step you could skip?
Old 07-20-15, 01:49 PM
  #66
STLblueF
STLblueF's Avatar
FYI- just tested this out while installing the Sewell stripped set. There's no need to ground the fifth (red) wire. Just run the green wire to the fuse tap and your set for them to be on when the car is on.
Old 07-20-15, 04:31 PM
  #67
teamcalvin
teamcalvin's Avatar
Ah sweet write up.. helped me a lot on mine.
Old 01-04-16, 06:15 PM
  #68
BenjNguyen
BenjNguyen's Avatar
Wonderful write up. Thanks a lot
Old 01-07-16, 11:02 AM
  #69
BenjNguyen
BenjNguyen's Avatar
Default Wire colors need to be changed
It took me 4 hours to do the wiring process only to find out in the comment section that the wire colors need to be switched. Green is power supply and red is the ground. My headlights are OEM 2012. I took me another 2 hours to remove the bumper and rewire. Now it work perfectly thanks to a comment. Thanks a lot guys.
Old 08-06-16, 01:04 AM
  #70
metaleckz
metaleckz's Avatar
Can someone please help me. I just installed the led headlight but the LED wont turn on? When i start the car. The led blinks for half a sec then gone
Old 08-06-16, 03:40 AM
  #71
Joker4096
Joker4096's Avatar
Where did you buy them from?
Old 08-06-16, 12:42 PM
  #72
metaleckz
metaleckz's Avatar
Ebay but got it to work now
Thanks!
Old 08-06-16, 02:02 PM
  #73
Joker4096
Joker4096's Avatar
Thanks!
What did you have to do?
Old 09-17-16, 01:58 PM
  #74
JDM-V8FL
JDM-V8FL's Avatar
very helpful thread!!
Old 09-17-16, 05:26 PM
  #75
DjMarkOne
DjMarkOne's Avatar
Thanks!
Those don't look too bad. Were they straight plug in & play?
Quick Reply: DIY LED 'stripped' headlight installation
