HELP!! Suspension THUMP noise
Here's a link. Recorded from my phone. You can clearly hear that one bump is really a CLUNK compared to some of the other bumps.
http://www.youtube.com/watch?v=SeGbi...feature=g-hist
Tech Info Resource
Any chance the cartridge is not fully tight in the shock body?
11 Second Club
OEM stuff is in the garbage LOL. I tend not to keep the old stuff around and clutter my life. I'll check to see if the cartridge is on or not... how do I do that?
Tech Info Resource
There's usually a top nut on the shock body that retains the cartridge. You'll probably have to take the offending unit off and remove the spring to tighten it.
The Maker
So, the rubber upper hats require compression of the bushing to get down to the sleave diameter. Check that you have the proper torque spec on the top nut and use a hex key and wrench to torque if not.
last step of this video http://vimeo.com/28427984
I am suspect some of these may not have been fully compressed from factory assembly or worked loose after driving leaving a small gap between the crush washers and the crush tube. This would cause a thud when the shock is loaded and unloaded as the crush tube bounces between the two washer limits.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Mike
Mike
11 Second Club
So, I went to a good mechanic and together we swapped right and left. We made sure everything on the shocks were tight (nothing was loose) and made sure we had the 4 mm or so or preload. Odd thing... Just switching right and left shocks removed the sound. I'm not sure what was the cause of the thumping, but the shocks were NOT changed at all except to swap right and left rear shocks. Maybe it was an installation issue? The nuts were all tight and torqued so I have no idea how we fixed it or what the cause was but either way, I'm super happy the SOUND IS GONE!!!
11 Second Club
thumping was in the right rear (farthest from me) and now it's gone... I was hoping to find a loose shock body or something but in the end, everything was already tight and just the swap removed the noise and it hasn't shifted to the left so it's definitely not a bad shock body (which is what I was guessing) nor an exhaust pipe hitting the frame.
Either case, I'm glad it's gone and now it's time for me to continue on modding. LSD anyone?
Mike
Mike
Hey, has anyone come up with an expanation and fix for the noise? I just had my BCs installed (with Swift spring upgrade) and got the car back last night. Today driving I notice that small bumps, in succession, seem to produce this loud noise from the rear (not specifically from the left or right), that sounds like a bag of wrenches or something bouncing around (there are no wrenches in my trunk). I am currently 12 clicks out from stiff, front and rear, although I find that first click to be somewhat ambiguous in the rears. I will check on the rubber hats as FIGS suggested. Anyone else having similar issues or solutions?
TIA
Kevin
TIA
Kevin
11 Second Club
I found out the cause. The suspension makes the exhaust rattle. Yup, my sound came back and after a thorough examination, my borla exhaust was hitting a hanger. Now, after moving the exhaust around, my rattle is completely gone.
