Borla Axle-back Exhaust - feedback thread
Old 02-25-13, 04:19 PM
  #31
anxiouz
anxiouz's Avatar
The axle-back doesn't remove cats so it will absolutely pass CA emissions.
I'm still not sure if cat-backs pass in CA (you don't have to smog a car for 6 years so even the 08's here having had to smog yet) but with the headers still having cats I think it will.
Old 02-25-13, 04:41 PM
  #32
Fivepoint0
Fivepoint0's Avatar
Passed Ca emissions with my borla cat back .
Old 02-25-13, 06:34 PM
  #33
flowrider
flowrider's Avatar
Received 1,828 Likes on 1,290 Posts
Originally Posted by Rossi
Are you indicating that the Borla cat-back will pass emissions or axle back.
A cat back system will pass an emissions check just fine, because removal of the secondary cats will not upset any of the cars electronics. There is no electrical emissions check (o2 bung) after the secondary cats. However, if there is a visual inspection and the inspector knows what he/she is doing, you will fail the visual inspection. Remember it is against Federal and CARB law to tamper with or replace the working catalytic converters on a motor vehicle. And yes, I know, I am breaking the law, and so are a lot of other members of this forum.
Lou
Old 02-25-13, 06:37 PM
  #34
vmatheboss
vmatheboss's Avatar
I'm assuming you were hooked up, or the tech didn't know it's aftermarket since the isf parts are hidden unlike Acura or Honda?
Old 02-25-13, 06:54 PM
  #35
Rossi
Rossi's Avatar
I was told by another member that he passed the smog with JoeZ exhaust in CA.
He stated that Lexus is in general a low emission car and had no problems passing the sniffer even without the secondary cat. I guess Borla cat back should be the same thing.
Old 02-27-13, 06:21 PM
  #36
jadeboy
jadeboy's Avatar
Originally Posted by caymandive
The Borla axle back does have a decent start-up and idle sound, but the exhaust sound didn't seem to be all that noticeable while driving compared to stock. What I did notice is that around 2000 rpm under load that it had an annoying but not loud "drone' sound which was surprising to hear considering how quiet the exhaust was otherwise.
Anyone know how to reduce this droning? I agreed at 2000 rpm, the drone is annoying. I have read from another there is a exhaust tip that borla could provide for free to reduce the droning.
I tried drowing the droning with 2012 IS-F ML audio system, unfortunately it sux, does not play loud enough and the good low bass is lacking.
Old 02-27-13, 06:25 PM
  #37
anxiouz
anxiouz's Avatar
The Borla axle-back cannot be "fixed" of this droning. Having some conversations with a few exhaust owners, it seems like the mid-pipe has more of an impact on overall sound. So you can't remedy the Borla axle-back of it's sound and drone. You either have to go cat-back, or....go custom crazy with what you have.
Old 02-27-13, 06:39 PM
  #38
AussieISF
AussieISF's Avatar
The key to removing drone is in the mufflers. If you can't live with the drone, go back to the stock mufflers.
Old 02-27-13, 10:42 PM
  #39
Rossi
Rossi's Avatar
After all the feedback, I think the cat-back is the way to go.
Any feedback on Borla cat-back? ( No JoeZ suggestions please)
Old 02-28-13, 07:27 AM
  #40
flowrider
flowrider's Avatar
^^^^Rossi, there's lots of feedback on the Borla Cat-Back system on this forum. Do a search and you'll find 'em. Generally most folks who have it like it.
Lou
Old 02-28-13, 10:48 AM
  #41
drphatmatt
drphatmatt's Avatar
I just came from a buddies shop that fabs exhaust system for race cars and builds unreal motors as well. His place is called welding works. He all kinds kick butt cars at his shop today. He was going to build a custom exhaust but as he examined the F on his lift he was stating the stock exhaust is really good, very free flowing ect.. He said if I want a system build to improve sound just changing the mufflers is the most practical way to go. Even the the Y point you have mentioned here is well desighned.
Old 02-28-13, 11:55 AM
  #42
flowrider
flowrider's Avatar
^^^^I respectfully disagree. Though I never baselined my F with the stock exhaust, most stock Fs run about 335 to 340 RWHP. My F, with only a modified dual system utilizing non-modified stock mufflers, no secondary cats and with the factory manifolds put out 355 RWHP on a DynoJet. That was the baseline dyno run for me before my PPE headers, hi-flow cats and modified stock mufflers. I can't understand how that crush at the rear Y can be described as well designed.
Lou
Old 02-28-13, 04:46 PM
  #43
anxiouz
anxiouz's Avatar
From under the car you can't see the crushed y-pipe as well so it may have been an oversight. But if you see it from above it will make you shake your head in disbelief.
Old 03-02-15, 02:08 AM
  #44
hamooduae
hamooduae's Avatar
i guess the axle back has nothing to do with any of the CHeck engine light !!
Please tell me coz am really disappointed after my first full exhaust system ...
if no CEL then ill go for borla axle back
Old 03-03-15, 09:24 AM
  #45
Rossi
Rossi's Avatar
Catback or axleback ...... No CEL if installed properly.
Quick Reply: Borla Axle-back Exhaust - feedback thread
