Allow me to introduce myself!
Name is Evan! Live in Houston, TX. Got a few things in the works for the ISF but here is what I have so far
Custom D3PE Cold Air Intake (still testing)
Rear Y-pipe/muffler delete
305/35/19 Mickey Thompson ET Streets on stock wheels
Here is the stock HP v.s. how it sits with the current mods:
Stock times I ran 13.19 and after the mods we got it to a 12.8 this past weekend. Much more in store!
Correct the only mods are the intake and rear Y-pipe removal. Unfortunately this particular unit cannot keep the stock scoop on there and gives the "unfinished" look but this is just a prototype so that could still change
It is definitely a tight fit but not too much modification needed in my opinion. Moved a couple brackets slightly, removed brake duct(simple to unbolt), and you do have to trim the plastic below the lower front frame rail a little or just remove that piece.
nice ride and good work on the intake! welcome to the F family!
Hello and welcome. Curious though... 324whp seems a little low for stock. Granted, a dyno is useful for measuring gains over a baseline in similar conditions, so it doesn't much matter what the baseline is, but I wonder if 324whp wasn't due to bad atmospheric conditions on that day. Put another way, can we really attribute 40whp to the intake and muffler delete, or could it just have been better conditions on the second day? Intakes, even CAIs don't tend to add a whole lot of power on the dyno, because most of the additional air that is added to the AF mixture comes from the cold air rushing into the intake at speed, but that doesn't work quite as well with a fan blowing onto a stationary vehicle.
Also, did you run the 13.1 with the MTs, or was that with stock tires?
