Will 18" IS350 rims fit ISF
Old 10-05-12, 08:28 AM
on6mt
on6mt's Avatar
Default Will 18" IS350 rims fit ISF
Hi guys,
I just recently purchased a 2008 CPO ISF and should be picking it up in the next bit.
Realizing I bought it right in time for winter I need to get a set of snow tires for it. As the title states, does anyone know if the 18" wheels off an IS350 will fit the ISF. I tried searching and couldn't get a straight answer. The IS350 rims are 8" in front and 8.5" in back with the same bolt pattern. I saw that there is difficulty fitting 19" ISF rims onto an is350 without spacers because of the caliper shape, but was wondering if there are any issues the other way around.
Any info and pics would be great
Cheers
Old 10-05-12, 09:15 AM
ISF4life
ISF4life's Avatar
fit perfectly
Old 10-05-12, 10:04 AM
rominl
exclusive matchup
rominl's Avatar
ask joez, he test fitted. i think the answer is no. outside of caliper (diameter wise) is touching the barrel
Old 10-05-12, 10:17 AM
ISF4life
ISF4life's Avatar
Yup, Henry is right ,the OEM ISx50 wheels are not clear the ISF calibers lolz,
Old 10-05-12, 10:23 AM
Namster
Namster's Avatar
Correct. Here's the link to JoeZ's test
https://www.clublexus.com/forums/is-...ll-w-pics.html
Old 10-05-12, 10:50 AM
on6mt
on6mt's Avatar
Thanks for the info guys much appreciated,
Guess I will pick something of tire rack in the 18" variety maybe sport edition or moda. Leaning towards these (link below) and a set of goodyear ultragrip ICE wrt in 225/45/18
http://www.tirerack.com/wheels/Wheel...RT&qty_front=4
Any thoughts
Cheers
Old 10-05-12, 11:05 AM
caymandive
11 Second Club
caymandive's Avatar
The 18" OEM G-Spider rims fit the F and a few have them on for the winter.
Old 10-05-12, 11:19 AM
604's Avatar
Is it the MM on Alpine?
Old 10-05-12, 11:27 AM
digger08
digger08's Avatar
X Package also fit . Its a close fitment, but no problem. I also used to run G-spider as Caymandive - clearances were identical.
Digger08
Old 10-05-12, 11:47 AM
on6mt
on6mt's Avatar
It is,
If you mean mercury metallic on alpine in richmond hill?
Old 10-05-12, 02:36 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Arrow
But I think (or remember) for the G-Spider... ONLY the Front 18x8 rims clear the rear.........
So basically you can only use 4 of the 18x8 wheels.. (not the rear 18x8.5")
~ Joe Z
Old 10-05-12, 02:43 PM
caymandive
11 Second Club
caymandive's Avatar
~ Joe Z
Yeah I believe you are right about that. I knew it wasn't a staggered setup.
Old 10-06-12, 08:12 AM
clarionguy
clarionguy's Avatar
Thank god for the above comment. i just bought 4 x 18x8 G spiders with Blizzak ws70's...
Bought TPMS sensors that were off a scion .. hope that works :S ... bought new fit kits ..
i was considering 2 x 18x8 and 2 for the rear 18x8.5 but then realized I would not be able to rotate the tires at all ...
Old 10-10-12, 05:37 PM
on6mt
on6mt's Avatar
Digger08
Thanks for all the info guys
For the X Package wheels, are they all 18x8 or are two 18x8.5?
Cheers
Old 10-10-12, 08:22 PM
digger08
digger08's Avatar
Cheers
Nope staggered, as Joe states 18 x 8 and 18 x 8.5
Digger08
Quick Reply: Will 18" IS350 rims fit ISF
