Wheel Spaces - Did I make a mistake?
I have a 2011 ISF with stock everything (rims, suspension, etc.) and just had the H&R TRAK+ 20mm (hub-centric) spacers installed in the rear. They were installed professionally at a wheel/tire shop.
But now, after seeing some of the posts here, I'm half tempted to get them taken off.
I'm not seeing any rubbing or noticing anything out of the norm.
Thoughts?
Thoughts?
Tech Info Resource
How do you drive your car? If you just cruise around town and you're willing to inspect them regularly (for your own safety), you'll probably be OK. If you do any kind of high speed driving, I would take them off for a whole bunch of reasons.
I had them on many of my cars in the past and had it on with my last set of wheels on my isf and never did i had a problem. Took the car at high speed and lots of cornering with my other cars with no problem. Im not speaking for all, but in my case it's not a big deal.
My driving habits are moderate to aggressive. I take it on the 1/8 and 1/4 mile tracks several times a year. I dont take corners at rediculous speeds, but I've been known to take the car up to 140mph
The only reason I wanted them was for the looks. The car handles just fine without them. I just didnt like how far back the rims were on the rear.
EDIT: What should I be looking for when inspecting them? Checking the lugnuts are secure?
Thats some relief to hear...I went with H&R because they seemed to have good reviews, and weren't some knock off made in China brand. German engineering weighed heavily on the choice.
Yea, the weight issue was very negligible (I think like 2 pounds each). I think I got the better of the ones that are out there...judging by what is posted on some forums etc.
Tech Info Resource
The thing to look for is cracking or stud damage. If either of these things happen, you want to fix it much sooner than later. There have been members with Ichiba type 2 spacers (the ones with their own studs) who have had cracking issues.
If you're just drag racing, simple inspection every 6 months or so should be fine. If you were autocrossing or running on a road course, I would recommend taking them off. They change suspension geometry in a bad way if you need to turn the car.
The extent of my racing is all straight line (either on a track or from stop light to stop light. Do I need to take the rim off to see the spacer, or should crawling under it be sufficient?
Are you running extended studs, or do these come with studs fixed on the spacer itself? I know many people who run spacers without issues, but I personally wouldn't do it... 20mm is a lot and you're really messing with the geometry and balance of the suspension. Don't mean to scare you though.
I drove with H&R 25mm spacers on my Supra for many many years, drag racing, street racing and made donuts, tested top speed and other strange things, never had any problems or suggestions in damage to the spacers, wearing out three sets of tires every summer, and the roads here in Norway is not the best in the world so you could say that these spacers were tested with all possible stresses.
But have no experience with other brands spacers.
