I have aftermarket wheels and i had dealer program a second set of tpms sensors. Apparently there is a switch under the glove box. I cant find it.. is there a panel you that you need to drop down? I looked all over. Dealer said its a switch that has a one and two on it. Any help would be appreciated.pics would be beneficial. Its an 09 isf.
i had an 08 GS, and it had a switch in the glove box. for the IS however, i think you just press the setting button next to steering wheel to choose 1st or 2nd set of TPMS.. correct me if i'm wrong.
i thought u switched between set 1 and 2 through the controls that are to the left of the steering wheel and i thought the button in the glove box was a reset button (its on the left side in the glove box)
Satellite switch (which also controls the AFS) will allow you to toggle between 1st and 2nd set of programmed TPMS sensors. I believe this is the same for 2008 and 2009 vehicles
