Pennzoil Ultra
Old 08-17-12, 07:54 AM
flowrider
flowrider's Avatar
Received 1,828 Likes on 1,290 Posts
Originally Posted by Just F Me
Just because a it's a Ferrari does not mean it's better. Dumbest logic I've heard today.
That's not what I was saying and I think you know that
And before you call someone else dumb, look in the mirror.
Lou
Old 08-17-12, 08:00 AM
zapa
zapa's Avatar
Originally Posted by Endgame
Don't they use Mobil 1 on the Z06 Vettes stock? If it is good enough for a Z06, it should be good for an F....
Just F Me i think this is what Low was making a joke about the previous post. I don't think you read it correctly
Old 08-17-12, 08:25 AM
DonTN
DonTN's Avatar
I'm waiting for obuxracer to chime in on this one.
Old 08-17-12, 08:47 AM
Endgame
Endgame's Avatar
Originally Posted by zapa
Just F Me i think this is what Low was making a joke about. I don't think you read it correctly
DHOH!
Old 08-17-12, 11:01 AM
Just F Me
Just F Me's Avatar
Lou
I never said that you were dumb....I said the logic behind it was. Perhaps I did misinterpret what you said because you didn't quote the previous post.
We all buy into marketing...I never pump anything except Chevron because those cars look so happy in those commercials...
Pennzoil claims 25% cleaner, but that's based on what intervals and what conditions? I think if you compare driving in LA, vs driving in Texas, it's all relative.
Old 08-17-12, 11:09 AM
flowrider
flowrider's Avatar
^^^^I didn't quote the previous post (or this post) because my post led off with:
Those arrows mean lookup at the previous post.
I'm with you on Chevron, but not because of happy looking cartoon cars, but because it's a top tier gasoline which, yep, marketing has led me to believe is better than other the others.
As far as oil, I did my research and have used Pennzoil products for years. But, any name brand synthetic will probably do the trick.
Lou
Old 08-17-12, 01:55 PM
rw95gt
rw95gt's Avatar
I was planning on using Mobil 1 in my F. I used it in all my past rides with no issues. I tend to change my oil every 3k miles in my cars and every 5k in my wifes car. I think.as long as its changed regularly and you run a synthetic oil it really doesn't matter what brand you run.
Old 08-17-12, 08:56 PM
Just F Me
Just F Me's Avatar
You actually don't even need to run synthetic in the IS F. IS F doesn't come from the factory with synthetic.
Old 08-17-12, 11:17 PM
flowrider
flowrider's Avatar
^^^^Ok, I think we all knew that What's your point
Lou
Old 08-18-12, 12:26 AM
Just F Me
Just F Me's Avatar
I highly doubt everyone knew this.......maybe everyone that's been reading and following along in this thread has, but there could be lurkers...
Also \I made the comment that you don't need to run synthetic because rw95gt said "as long as it's changed regularly AND you run synthetic oil..."
You can change the oil regularly with conventional oil and it will probably be just as clean with all other things equal.
Personal opinion is that all oil is pretty good and it's more about the environment your car is driven in, how often you clean/replace your air filter/oil filter, and how often you do your oil changes. Most oils don't sludge up unless you're driving the car for excessive miles without changing it. Oil probably makes a difference (I say probably because I don't know from my own experience) if you drive the car hard...might be better to go with a higher quality oil that doesn't break down at excessive heat levels such as synthetic oils
My car has a lot of miles on it now...and I drive it pretty hard. It probably gets redlined 6-10 times a day when I drive it if not more.
I was thinking about switching to a 10w-30 Mobil 1...what do you guys think?
Old 08-18-12, 05:10 AM
DCoolBeans
DCoolBeans's Avatar
^ Dude are you serious??? I asked about thoughts on this Ultra oil.
Old 08-18-12, 08:08 AM
rw95gt
rw95gt's Avatar
I have always been told once you run synthetic you should always run it. True?
Old 08-18-12, 10:16 AM
Just F Me
Just F Me's Avatar
Hijacked your thread...sorry I think you should take your engine apart, check it out, take pics, then use Pennzoil Ultra and in like 50k miles, take your engine a part and see if it's true. I mean, there's really no way of knowing unless this is what you do. It's all marketing. Which is better...vitamin water or gatorade?
Oil is oil...some have more additives than others...etc.
http://www.valvoline.com/car-care/motor-oil-myths/
http://www.mobiloil.com/USA-English/...ollection.aspx
http://autotechdiagnostics.com/?p=76
Old 08-18-12, 04:47 PM
2ndGF
2ndGF's Avatar
That's like comparing apples to oranges - gatorade is more electrolyte based with more sugar - vitamin water focuses on different vitamins depending on what you are looking for that day ;-)
MOBIL 1
Last car used nothing but Mobil 1 for 6 years and 200,000 miles in the hot dusty Arizona desert with oil changes every 6,000 miles with 0 engine problems. Like In-N-Out, that's quality I can taste!
Old 08-18-12, 05:37 PM
Just F Me
Just F Me's Avatar
you tasted the oil?
Quick Reply: Pennzoil Ultra
