CL Vendor Products for IS-F New product details, group buys and more, specifically for the IS-F model from CL Vendors
New Product Front F Bushing offering and eye opening video inside.
Old 07-21-12, 11:27 AM
  #31
ilv1004s
ilv1004s's Avatar
so this would apply to all IS platforms right?
Old 07-21-12, 11:30 AM
  #32
FIGS
The Maker
FIGS's Avatar
correct, the requirement for the stiffest bushing may not be necessary on a 250 but the 350 dependin on how you drive it certainly can benefit from the 90 duro bushing.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 07-21-12, 12:35 PM
  #33
ilv1004s
ilv1004s's Avatar
thanks for the info
we are in the proccess of making a race car from a 350
after reading through this thread
it seems its a must for the race car
Old 07-21-12, 09:25 PM
  #34
Supraman16
Supraman16's Avatar
So I just ordered these bushings and am pretty eager to get them installed along with my new tires. What will be the best toe specs now for prolonged tire life?
Old 07-21-12, 10:09 PM
  #35
Autobacs
Autobacs's Avatar
Well the accepted spec for toe-in for prolonged tire life is zero degrees or very slight toe-in. Obviously with this information on the flexibility of the LCA bushing, the front tires will toe-out on braking regardless of your static toe spec.
With this bushing, toe out under braking is minimized so I am speculating that even with maximum toe out (within specs), the inner tie wear issue should be minimized.
Mike or Lobuxracer, what do you think?
Old 07-22-12, 08:57 PM
  #36
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,842 Likes on 2,330 Posts
Agreed. I'm only waiting for the NVH report on the solid bushing before deciding which I will install.
Old 07-30-12, 04:07 PM
  #37
Sango
Sango's Avatar
Sounds like a great solution. Seems like ride quality is unaffected that people could install in their 250/350 if they are experiencing issues.
Old 07-30-12, 05:02 PM
  #38
lobuxracer
Tech Info Resource
lobuxracer's Avatar
I recall this being an issue was back in 2006 when I bought my 350, so, it's not so much if they're experiencing issues. It's something I would recommend to almost anyone with any 2IS.
Old 07-30-12, 08:38 PM
  #39
FIGS
The Maker
FIGS's Avatar
For those that ordered I should have the correct, centered bushings shipping today. They sent the eccentric version previously and I have not characterized the impact on roll center and dynamic toe and caster so I did not want anyone testing that as well. Orders should ship next week. Hopefully get the sphericals on this week.
__________________
Old 07-31-12, 08:16 PM
  #40
Sango
Sango's Avatar
Just curious what difference about the eccentric and spherical version? I'm not quite familiar with bushings.
Also, is there an increase or decrease in road noise switching to these bushings which one maybe concerned about for general street use?
Old 07-31-12, 11:18 PM
  #41
RCB
RCB's Avatar
Eccentric=offset mounting point which will change the alignment setting.
Spherical=Solid steel ball and socket with a Teflon lining. This has the least deflection but possibly the most NVH
NVH=Noise, Vibration and Harshness. This is the concern that everyone is trying to determin the levels of with the different bushing options.
Hope that clears things up for you.
Old 08-01-12, 09:47 AM
  #42
FIGS
The Maker
FIGS's Avatar
right, this is a pic of the eccentric version
vs this one
__________________
Old 08-01-12, 10:33 AM
  #43
UCrazyKid
UCrazyKid's Avatar
is the "poke" issue addressed in this design?
Old 08-01-12, 11:14 AM
  #44
FIGS
The Maker
FIGS's Avatar
It is mitigated but not resolved completely. Until the bushing is silid there will always be a little deflection. The OEM bushing allows more poke because it has very little constraint and the vector of the movement is both poke and push.
I am swapping in an LSD right now so hopefully get humpty back together and do some testing with the spherical bearings.
__________________
Old 08-01-12, 12:11 PM
  #45
LiLS
LiLS's Avatar
so if my isf is slammed whichj version would i want to run
Quick Reply: New Product Front F Bushing offering and eye opening video inside.
