Will Michelin PSS 295/30ZR19 fit?
Hi all, just wondering if the PSS 295/30ZR19 fit the 2010 stock wheel? I know for sure 275/30ZR19 will fit just fine. However, not sure about the 295. My car is lowered with rear shaved fender. Any input would be greatly appreciated. Thanks!
Yes, that is definitely too wide to put on a 9" wheel. You could put it on the 2012 wheels though which are 9.5"...that's about as narrow a wheel as I would ever consider putting a 295mm (19"wheel) tire on. The 2012 wheels should be able to handle 255/35R19 front tires and 295/30R19 rear tires without any fender mods. That would be some serious meat on stock wheels. I would like to see somebody do that.
I am running 285/30/19 Bridgestone S-04 PPs on my stock wheels. IMHO, 295/30/19 would be too wide for 9" wheels. As Gymkata has suggested, I believe they would fit on the newer 9.5" wheel. If the PSS had been available in 285/30/19, that's what I would have chosen. Although, I am quite happy with the S-04s.
Lou
Lou
specie
Suspension and Brakes
09-08-13 02:03 PM
