10K service, and I need what!!!???
Old 07-11-12, 04:25 PM
kbtoiz
kbtoiz's Avatar
Default 10K service, and I need what!!!???
Well I just came from the Lexus dealer to perform the 10K service. I asked about the TSB for the front brake pads, they were going to check. When I talk to the service rep, he told me that the car needed brake pads and rotors!!!! A car with 10K!?!? And to my good luck, the TSB doesnt cover me cause the pads are wore 1mm below the limit to cover!!! Seriously!?!?
Does this sounds alright to you?? I cant fraking belive this BS!!!!
Old 07-11-12, 04:56 PM
2ndGF
2ndGF's Avatar
Unless you drive everywhere with your emergency brake on I don't see how that is possible. Im at 11k and nowhere near needing new pads or rotors.
Old 07-11-12, 04:57 PM
FastPaced
FastPaced's Avatar
Something is wrong here..
Old 07-11-12, 05:14 PM
Just F Me
Just F Me's Avatar
You can take off your wheels and see how thick your pads are...that's #1
Also...front OEM rotors under normal driving conditions should last you 30-40k miles. OEM front rotor thickness 30mm new, minimum thickness 28mm
Front pads last around 25-35k. New pads 9.8mm, minimum thickness 1.0mm
Rear pads lasted me almost 70k miles, and i'm still on my original rear rotors at 83k miles.
New rear pads 11.5mm, and minimum thickness is 1.0mm.
Rear brake rotor is 28mm new, 26mm minimum.
Time to learn how to do your own brakes so you don't get ripped off by the dealer...
Last edited by Just F Me; 07-11-12 at 07:44 PM. Reason: 30mm is new front rotor not 32mm
Old 07-11-12, 05:25 PM
kbtoiz
kbtoiz's Avatar
Also...front OEM rotors under normal driving conditions should last you 30-40k miles. OEM front rotor thickness 32mm new, minimum thickness 28mm
Checking this is the first thing Im going to do when Im off Friday. I already started reading on rotors and pads DIY they have around here. Yes, it is a good time to learn! Im pretty sure thats how the dealer put the shaft on people, but come on! How to tell me I need all that with 10k!?
Old 07-11-12, 05:29 PM
NYC ES3
NYC ES3's Avatar
I believe its a minimum of 3mm? no?
1mm is like nothing is there
Old 07-11-12, 05:43 PM
kbtoiz
kbtoiz's Avatar
I dont remember exactly how much its was, but definitely he said I was 1mm below the limit to be covered under the TSB. How convinient for them uh!
I was in disbelief and disturbed when he was talking
Old 07-11-12, 07:43 PM
Just F Me
Just F Me's Avatar
Straight from the Lexus IS F Factory Service Manual BTW...made a mistake, it's actually 30mm thickness for new front rotors not 32mm.
Old 07-11-12, 07:57 PM
DCoolBeans
DCoolBeans's Avatar
This is why I love these forums People like Just F Me
ps OP your dealer is full of bull poop
Old 07-11-12, 11:20 PM
Kingkrs
Kingkrs's Avatar
Where can I get a copy of that manual? is there a website that you can direct me to? Thanks
Old 07-11-12, 11:26 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,845 Likes on 2,332 Posts
techinfo.toyota.com. All manuals for everything Scion/Toyota/Lexus for more than 20 years back.
Service manuals are pretty boring. The New Car Features books are pretty awesome.
Old 07-11-12, 11:35 PM
1sWt2GS
1sWt2GS's Avatar
the wear shouldn't be near that bad for 10k
Old 07-11-12, 11:36 PM
Fobbers
Fobbers's Avatar
Cant you go to a different dealer for a second opinion?
Old 07-11-12, 11:42 PM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
you are being taken to the cleaners
Old 07-12-12, 02:51 AM
kbtoiz
kbtoiz's Avatar
[quote=Just F Me;7352274]Straight from the Lexus IS F Factory Service Manual BTW...made a mistake, it's actually 30mm thickness for new front rotors not 32mm.
This guide is awesome! THANKS!
I like this forum cause of all the help you get here! People always willing to help rookies!
THANKS!!
I was wondering the same thing. Theres another about 50 miles, but I guess they must have the same owner and I think they might comunicate between each other...
Quick Reply: 10K service, and I need what!!!???
