Is it supposed to look like this?
Old 07-07-12, 07:24 AM
Gymkata
Gymkata's Avatar
Default Is it supposed to look like this?
While opening the intake box to clean my Tom's air filter, I disconnected the connector hose between the intake box and the JoeZ intake pipe. I saw that the exit area of the intake box where it meets the rubber connector hose seems bent. Is is supposed to be like this? I don't think so. I think I must have tightening the clamps a little too hard when I installed the intake a couple years ago. Anybody know for sure? Is this an issue? Thanks in advance.
Old 07-07-12, 07:42 AM
RCB
RCB's Avatar
It's not supposed to look like that. You did tighten the clamp to much. That is from the collar on the clamp digging in at an angle.
If the coupler is long enough slide it on till it buts up against the sensor and slide the hose clamp to the edge. Put the collar for the worm gear in a different position. Watch the silicon when your tightening. You'll see when the clamp is digging in to much.
If you can't get it right try to heat that plastic with a heat gun and work the shape back into it then leave it in a freezer for an hour to harden back up.
Old 07-07-12, 09:26 AM
Gymkata
Gymkata's Avatar
Thanks RCB...will try your suggestions
Old 07-07-12, 01:45 PM
aWorkOfArt
aWorkOfArt's Avatar
Yikes! Yup not normal, but just do exactly as RCB said, but i would fix it first rather than just reattaching the clamp closer towards the sensor. It would affect the air flow, maybe not significantly enough, but in the back of my mind it would bother me if i didnt fix it hope you get it all worked out bro
Old 07-08-12, 06:46 PM
iH8RICERZ
iH8RICERZ's Avatar
mine looked the same when I went to install my Joe-Z intake. The previous owner or dealer that sold it to me must have done it :/
Old 07-08-12, 08:26 PM
RX7 RAGE
RX7 RAGE's Avatar
Mine looked like that too.
Old 07-09-12, 04:38 AM
caymandive
11 Second Club
caymandive's Avatar
Same thing happened to me during a filter swap. That was the point where I swapped back to stock.
Old 07-09-12, 06:33 AM
cdxsuprace
cdxsuprace's Avatar
Mine look the same too when I install the JoeZ intake.
Old 07-09-12, 03:09 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Exclamation FYI for All...
In case some of you missed the printed instructions...
Line# 13 - Ok, now that everything is on, and the pipe is at the right angle… you can tighten the screws on worm clamps with flat head screwdriver or 8mm mini socket wrench with extension. The socket wrench is easier. Do not over tighten!!
Line# 15 - While that is happening go back to the clamps and give them another small turn or two with screwdriver or socket wrench as the sleeves will set themselves and may need to be tightened some more. Just don’t over kill the screws/bolts; that goes for any type of installation.
Sorry to see this happen guys, but there is NO need to make the clamps SUPER tight over the silicone sleeves or plastic inlet tube...
As noted my other members, this can easily happen with the OEM pipe & Clamps as well...
~ Joe Z
Old 07-09-12, 03:36 PM
flowrider
flowrider's Avatar
Received 1,813 Likes on 1,280 Posts
I'm embarrassed to say I did the same darn thing when I put in my JoeZ. But, I replaced that with the Takeda 2 years ago
Lou
Old 07-10-12, 08:00 PM
s2k636
s2k636's Avatar
I did the same on mine too.
varithms
RX - 1st Gen (1999-2003)
15
02-24-12 07:44 PM
niebla
Performance
05-26-10 12:01 PM
Frankdorn
09-16-08 01:00 PM
newis350
Performance
04-30-07 12:33 PM
bizarreRide
12
06-13-02 07:31 AM
Quick Reply: Is it supposed to look like this?
