Brake pads / rotors / tires replacement?
Old 06-15-12, 08:44 AM
2ndreality
2ndreality's Avatar
Default Brake pads / rotors / tires replacement?
Getting to the point where I need to replace my pads, rotors, and tires. Looking for something a little better than OEM performance, hopefully for also less than OEM price. Any good suggestions? I've seen different pads mentioned however not much on rotors/tires.
Any help is appreciated; also note I do not have separate winter wheels/tires so these would be on year-round. I will be doing no driving in snow though if I can help it (live in MO, so 5-15 days of snow cover per year at most, with moderate depth).
Thanks!
EDIT: If it matters I have a 2008.
Old 06-15-12, 08:58 AM
VtotheJ
VtotheJ's Avatar
A few members on here have Wearever Ceramic brake pads, they are WAY less dust than OEM pads. $50-60 a pair for rear& front (~$120 for the whole set). For rotors, you can go with either Centric or Raybestos from Rockauto.com.
There are a ton of threads on tires.
Track heads can chime in regarding track setups...
Old 06-15-12, 09:08 AM
2ndreality
2ndreality's Avatar
Are there any pads that won't require replacing rotors each time? Or is that just a given with the F?
Old 06-15-12, 11:15 AM
flowrider
flowrider's Avatar
Received 1,815 Likes on 1,281 Posts
There's so much written here about brakes (there's a thread dedicated to pads and rotors and places to buy them and what to pay) and tires (talking about brands and differing sizes) that I can't begin to list them all. Do a search
Lou
Old 06-15-12, 01:03 PM
ERDoc74
ERDoc74's Avatar
rotor replacement is pretty much always dictated by rotor width (wear)... you don't have to change them just cause you're changing pads...
Old 06-15-12, 01:08 PM
2ndreality
2ndreality's Avatar
I just got done reading through the very long thread on it. I still don't know what I want to do for replacement pads/rotors, but I will be measuring rotors before replacing now.
Old 06-15-12, 01:17 PM
VtotheJ
VtotheJ's Avatar
28mm or less, rotors need replacing.
Old 06-16-12, 03:32 PM
MWhit02
Registered User
MWhit02's Avatar
i'll be going with the Wearever pads based on others experience
airjordan1
05-12-17 06:33 PM
Jtecnik
11-17-16 11:29 PM
SC300P
Suspension and Brakes
09-16-11 04:52 PM
VIPNiSS
08-24-10 11:34 AM
saelee39
12-20-09 08:09 PM
Quick Reply: Brake pads / rotors / tires replacement?
