Which Wheel for track duty?
Old 01-21-15, 11:43 AM
  #46
BS ISF
BS ISF's Avatar
juan, yes they will fit no problem.
Old 01-21-15, 01:41 PM
  #47
juanmedina
juanmedina's Avatar
never mind...
Old 01-21-15, 10:46 PM
  #48
I8ABMR
I8ABMR's Avatar
Originally Posted by ERDoc74
So here's the pics of the TSW Interlagos I got instead... Definitely not as sexy as the Enkie's but they were cheaper at least.....
SPECS: 18x9.5 +40 offsets
Since the Hankooks are unavailable, I ordered some Nitto NT01's (they are based off the Toyo RA1's but with stiffer sidewalls and updated tread pattern) they supposedly last longer than most R-comp tires and also have a good reputation for heavy cars...
SPECS: 275/35/18's
Also got some Rays Engineering extended Lug nuts in anodized blue.
Pics below
Thanks for posting this After toasting a set of rears in less then 6-7k I am thinking a set of track wheels and tires would be a decent investment . How much did the tires cost , if you dont mind me asking
Old 01-23-15, 05:30 AM
  #49
juanmedina
juanmedina's Avatar
How can I know if the wheels will clear the calipers? they weight 19 lbs
Old 02-25-15, 12:16 PM
  #50
bbong
bbong's Avatar
Well, I got PF01's 18x9.5 +45mm and ordered some NT05's (265x35x18), I know they'll fit on the rear, but want to try the front first before I go with 265 all around. This thread has some great information
Old 02-25-15, 03:50 PM
  #51
darbs242
darbs242's Avatar
It's gonna be real close in the front but please post pics!
Old 02-25-15, 04:37 PM
  #52
Compthis
Compthis's Avatar
I burned through a set of Hoosier R6 285/30/18 square last summer. 265's will not be an issue. This summer I will be going with a set of 275/35/18 Hoosier R7's. Apparently the R7 lasts longer, wears more even and sticks more. I can't want to try them out.
Old 02-26-15, 08:52 AM
  #53
Gymkata
Gymkata's Avatar
That will not be an issue. I just bought the exact same wheels and I'm going to mount 275/35R18 Toyo R888 tires on them.
Old 02-26-15, 08:58 AM
  #54
bbong
bbong's Avatar
That is good to know, really and honestly. I couldn't get a concrete answer in regards to the wheel size I should go with, but I pulled the trigger on 9.5's. I'm suppose to get the 2 tires tomorrow and going to try it out, but if you guys are saying it wont be an issue at all in front, I may as well order the other set of 2 tires.
Once I rip through 265's I'll definitely step up to 275 and maybe 285 if it is not an issue. Sorry for hijacking and thanks for all your answers!
Old 02-26-15, 09:08 AM
  #55
Gymkata
Gymkata's Avatar
If you consider 285mm in the future just realize that those running a square 285mm setup are running much shorter tires than stock. Close to stock height would be 285/35R18, and to my knowledge nobody has run this size on all 4 corners. It might fit, but I doubt it without trimming...especially if lowered.
Old 02-26-15, 09:16 AM
  #56
bbong
bbong's Avatar
Right now I think I'll just burn through 265's. I don't plan on modifying ride height in the ISF, from what I hear, the 2011 suspension is pretty good, so going to stay with that, at least for this season. Get to know the car as I mostly tracked (Evo's and Subaru's), probably RWD will be something to get used to first.
Old 06-10-16, 11:07 PM
  #57
shyguyF
shyguyF's Avatar
Sorry for bringing back the old thread!
Does enkei RPF01 18x9 +35 clear the front calipers of the ISF? I'm thinking of getting a square setup too. Is anyone here running Enkei RPF01 wheels?
Old 06-10-16, 11:47 PM
  #58
idoke1
idoke1's Avatar
The rpf01 will not clear the front bbk. I had tried and it did not clear. The pf01 does clear depending on size.
Roobarb
RC - 1st Gen (2015-present)
18
04-30-19 07:16 AM
GetUrWheel
Club Lexus Vendor Marketplace
107
08-10-18 01:18 PM
ERDoc74
IS F (2008-2014)
17
12-31-14 07:46 PM
oztiks
IS F (2008-2014)
11-10-09 07:41 PM
Mrbig
Northeast
07-21-08 07:24 AM
Quick Reply: Which Wheel for track duty?
