Ventross diffuser and S4play diffuser together?
so I have a S4play diffuser on my F...I just received a Ventross diffuser as well....
is anyone here able to have both piece on your F ? its doesn't seems like its possible :-(
UPDATE on 2012 June 20:
So, my local body shop was ABLE to put those pieces on my ISF...however, they did a half *** job. Instead of mounted the Ventross on first and then adjusted the S4Play, they did it oppsite.... and now people can barely see the S4Play sharkfins under my Ventross.
I was told by Rick (S4Play) that's a better way to do it to show all the Sharkfins even with the Ventross on it. So if anyone here have or know someone have same set up as mine. Please post some pictures so I can fix this and get it right. Thanks!
They did it wrong....the S4Play is trapped behind the Ventross :-( it suppose to be mounted on the edge of it.
You can Barley see the sharkfins.
I've got the S4play but not sure about its compatability with the Ventross. You may be able to trim down the S4play (since it's pretty thin plastic) after installing the Ventross and see if it will mount up.
Good luck, let us know what happens
If anyone in NORCAL, bay area has the Ventross and wants to help me do a test fitment with pictures, shoot me a PM
The OP and us are on opposite coasts so very hard for us to get together obviously
The last guy that did this combo was from socal but he has disappeared ever since we did the installation so no pictures sadly.
jasonson
09-05-14 01:58 PM
liqinwei26
01-12-14 09:19 AM
