My first 3m di-noc project
Old 04-30-12, 08:54 PM
RCB
RCB's Avatar
Default My first 3m di-noc project *revision*
I wasn't happy with the black plastic center tray in the back seats.
I looked at the Think Design CF panel but at $1000 I know that I will never pull the trigger on that part.
I have never used a CF wrap before, I've alway had a thing against imitating a product.
That being said I decided that for $50 (enough for 2 attempts) it wouldn't hurt to be open minded and give it a try.
I didn't do a great job on my first try. I avoided using the primer with the thought that I might mess up so I saved it for my 2nd attempt.
The edges came out pretty bad, lots of wrinkles. I also had a little trouble getting it to stretch and stick to the contures in the middle. Otherwise, I really like the look and I'm really happy I gave this a try!!!
I'm going to do it over and hopefully get it right next time.
Let me know what you guys think and please if anyone has suggestions for me on how to do a better job I would appreciate the input.
And sorry about the really bad iPhone pics in the dark, it was getting late.
Old 04-30-12, 09:04 PM
Pqbrown
Pqbrown's Avatar
Looks good. I've been wanting to do the same thing since my plastic is pretty scratched up. I'm curious to see what their silver version looks like in comparison to our texallium.
Old 04-30-12, 09:24 PM
RCB
RCB's Avatar
I had the same issue, some scratches on the plastic.
I almost went for the silver version but then decided that if it didn't match perfect (and it won't ) I wouldn't like it.
I thought the black would be more suddel and blend well with the seat like the black plastic did.
I could be wrong though. If you try the silver post some pics, I would love to see it.
Old 04-30-12, 09:48 PM
obby
obby's Avatar
not bad....
Old 04-30-12, 09:50 PM
boostftw
boostftw's Avatar
looks good may I ask where you bought this kit?
Old 04-30-12, 10:39 PM
IceIridium
IceIridium's Avatar
OT: How do you take the tray out?
Old 04-30-12, 10:41 PM
CalitriSC
CalitriSC's Avatar
I like how it looks. I just wonder about it not matching the silver carbon up front though..
Old 04-30-12, 10:45 PM
ISF4life
ISF4life's Avatar
U got to take out the rear seat out, and then unclips the rear console.
Old 04-30-12, 10:52 PM
DekNgo
DekNgo's Avatar
It looks pretty good. I'd like to see how rev. 2 turns out.
Old 04-30-12, 10:56 PM
iffy08
iffy08's Avatar
Really??? That's pretty intense just to get that out. Is that what you did OP?
Old 04-30-12, 11:54 PM
PrezJay
PrezJay's Avatar
Looks good... I used a similar material but thinner on my 335's interior and it turned our really good. I bought it from Project 808 but it looks like they are out of business. I'll try to dig up the material I used since it was really easy to work with and already had an adhesive backing so it was literally stick then smooth out.
Old 05-01-12, 12:06 AM
NotnFsport
NotnFsport's Avatar
Its pretty easy to take out the tray.less then 5 min
Old 05-01-12, 04:38 AM
RCB
RCB's Avatar
It really is easy to take out. There are to tabs at the front of the seat. One at the center of each cushion where it meets the floor. You pull up on those and the seat comes loose. Slip the seat belt buckles out and your done. Flip tge seat up and you'll see that the tray then unclips from the frame.
It takes a minute or less for the entire process.
Old 05-01-12, 04:45 AM
RCB
RCB's Avatar
Thinner and sticky might help.
Let me know if you find the info.
The 3M stuff only gets soft with heat. I had a little trouble when working one corner with the heat and at the same time the heat undoing my work on the other corner. I might have better luck with another set of hands.
I also watched some videos last night and they where heating up the entire sheet before laying it down.
Old 05-01-12, 04:50 AM
RCB
RCB's Avatar
I bought it on Amazon from Metro Restyling
You can also get it here:
http://www.carbonfiberfilm.com/blog/3m-carbon-fiber-di-noc-now-available-in-7-different-colors/
Or just google 3M Di Noc... There are a ton of places offering it.
Quick Reply: My first 3m di-noc project
