ARKYM IS-F Front and Rear bodykit revisted.....
Old 01-29-13, 04:21 PM
  #91
rapsquared
rapsquared's Avatar
bumper looks familiar!
Old 04-17-13, 12:52 AM
  #92
dorkacho
dorkacho's Avatar
haha this thread was over looked
Old 03-06-14, 08:42 PM
  #93
vmatheboss
vmatheboss's Avatar
I just got the front lip and rear diffuser. My diffuser only had two holes at the bottom, it lines up perfectly with the bumper clips. I drilled the holes a little larger so the bumper clips can fit right in.... so does the diffuser only hold together with those two clips and 3m tape? I notice that the corner of the diffuser overlaps a screw on the bumper, but there's no hole on the diffuser for that bolt....did you guys drill a hole for that bolt? Thanks
Old 03-11-14, 10:46 AM
  #94
RCB
RCB's Avatar
I drilled those holes out and utilized those mounting points. I also used 3m tape at first but I wasn't happy with the top edge. I kept getting pin needles, etc. stuck in the crack. I ended up pulling my bumper and riveting through the back side of bumper and in to the diffuser. I have a very tight fit and no worries about tape separation.
My way isn't for everyone since you put a bunch of holes in the bumper cover. My thinking was that if I ever change it I would go to Toms and it would cover the holes. If I ever go back to stock I'll buy a new bumper cover.
Most guys use the 3m tape and some have used body glue. The body glue would require paint work if removed.
Old 10-24-14, 05:48 PM
  #95
SpencerISF
SpencerISF's Avatar
Trying to find this kit, anyone know where I might find it?
Old 10-24-14, 06:15 PM
  #96
Sean
Sean's Avatar
Check pyspeed.com.
Old 10-26-14, 02:55 AM
  #97
ljdsong
ljdsong's Avatar
Go to ebay, its made to order.
Isfast
IS F (2008-2014)
25
05-06-17 01:03 PM
hederr
IS F (2008-2014)
12-18-15 11:51 AM
KSLAM
IS F (2008-2014)
28
03-30-15 03:35 PM
Joe Z
IS F (2008-2014)
30
12-14-09 11:23 AM
ngl1145
IS F (2008-2014)
45
10-14-09 04:14 AM
Quick Reply: ARKYM IS-F Front and Rear bodykit revisted.....
