Prepping car for 1/4 mile runs
Old 03-23-12, 11:23 AM
VtotheJ
VtotheJ's Avatar
Default Prepping car for 1/4 mile runs
I took 2 comparison videos of my acceleration with the TOMS throttle controller turned on and off. Now it's time to do it legally. Would you track heads tell me what I need to do to prep the F for quarter mile runs? I will list some below and you can add some things to the list. I am considering this since I currently have 2 Bridgestone Potenza RE050A tires with 17K miles on them sitting in the garage and may get the rears and use them as track tires (don't want to switch up brands). Is there a major difference between all-season and summer tires in a qtr-mile? I currently have all-seasons.
- Make sure there is less than 1/4 tank of gas
- take out spare
- remove everything from trunk
- Go to the bathroom
I would think it requires less prepping than actually tracking the car since there are no turns, just straight line runs.
Old 03-23-12, 11:41 AM
ISF4life
ISF4life's Avatar
Remove all accessories , and dont forget about the engine cover , 1/8 of tank and mix with 93 octane to 1/4 . or at least 1 gallon or 2... all floor carpets remove lolz , manua bookl . dont forget to work on your calves muscle lolz... and let roll .
Old 03-23-12, 01:38 PM
Gymkata
Gymkata's Avatar
What do you mean mix with 93...that's all the east coast has as far as I know...it is only the west coast that gets stuck with 91 (at least when I lived there 10 years ago).
Old 03-23-12, 01:41 PM
ISF4life
ISF4life's Avatar
Then you r good to roll lolz
Old 03-23-12, 01:46 PM
Evil Teo
Evil Teo's Avatar
actually we have the option to put race gas but I just recommend sticking to 93. Most of the drag strips should have it. But you will be paying over $4 over here VJ. Well in Jersey that is.
Old 03-23-12, 02:04 PM
VtotheJ
VtotheJ's Avatar
Are there major performance differences between all-season & summer tires on the track?
Old 03-25-12, 08:00 AM
TripleBlkF
TripleBlkF's Avatar
Take out a couple psi in the rear tires
I heard NOT to go through the water box, drive around it. (the F should hook up ok)
Also, you could use/drain your washer fluid - who needs that stuff anyway?
Old 03-25-12, 08:11 AM
hahahaf
hahahaf's Avatar
search around about gas
apparently our cars can only utilize 91
anything above has no improvements
from what I've read
Old 03-25-12, 10:25 AM
MRxSLAYx
MRxSLAYx's Avatar
You should realize a good difference in permanence depending on your power level. I would stick with the summer tires if your planning on posting a respectable time.
Old 03-25-12, 10:46 AM
Nova
Nova's Avatar
for competiton:
dont eat a heavy meal or drink sugary drink (energy drinks are a no)
relax and leave when you see the third yellow come on. if you leave on green you will lose
for testing or personal best u can use the same above or leave when u feel comfortable. it is not unusual for people to wait 10seconds to leave in order to get the launch just right but dont sit there for more then 30seconds as you will **** people off. also if you break, blow a hose, ANYTHING PULL OVER IMMEDIATELY i cant stress that enough as the farther u drag the mess the longer it will take to clean the tack
have fun
Old 03-25-12, 10:49 AM
Nova
Nova's Avatar
also if u are running street tires doing a burnout wont help nor will letting air out of your tires. you can over fill the fronts a little
Old 03-25-12, 11:24 AM
qsz06
qsz06's Avatar
Take out floor mats and spare tire . Run as little gas as possible. Raise front tire pressure to 40-42 psi creating less rolling resistance. Have fun and get a good launch!
Old 03-25-12, 03:58 PM
jkeifer3
jkeifer3's Avatar
Default What are you expecting to find?
The throttle controller won't allow the car to make any more power so I am not completely sure what you are expecting. If the controller can guarantee a better launch, on the other hand, then you may see better times.
Jetstar
Hybrid Technology
04-27-19 10:41 PM
silvaIS
Performance
08-02-15 09:24 PM
GRPFAN
Wheels, Tires & Brakes Forum
03-16-14 12:28 PM
Spacepig
12-19-09 12:52 AM
tt061880
11-12-06 08:32 AM
Quick Reply: Prepping car for 1/4 mile runs
