need help with a ignition turn on signal under the hood
Old 02-28-12, 06:32 AM
DemosISF
DemosISF's Avatar
Default need help with a ignition turn on signal under the hood
does anyone know the best place to tap into for a ignition on power wire to turn on a pump?
Old 02-28-12, 07:11 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,077 Likes on 2,471 Posts
What's the current draw on the pump?
Old 02-28-12, 07:13 AM
DemosISF
DemosISF's Avatar
its running a oil scavenge pump have it wired into a relay and needs that ignition turn on wire signal...im guessing less than 5 amps. thank you
Old 02-28-12, 07:16 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Do you want easy to get to, or right for the application?
The fuel pump relay does the same thing. If I were doing it, I'd use the same signal the fuel pump relay uses. It's switched power and tied to IG2.
Old 02-28-12, 07:20 AM
DemosISF
DemosISF's Avatar
would you happen to know in which fuse box its located in? is it the one by the battery ?
Old 02-28-12, 07:28 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
It's on the driver's side.
Fuel pump relay:
Here are your options with wire colors:
Attached Thumbnails need help with a ignition turn on signal under the hood-switched-power.jpg
Old 02-28-12, 07:43 AM
DemosISF
DemosISF's Avatar
Thank you very much!
Desacatao
03-03-19 03:09 PM
SCFactory
Performance & Maintenance
02-15-16 04:54 PM
92lexi
10-18-14 04:55 PM
MIGS
SC- 1st Gen (1992-2000)
12-18-10 07:07 PM
attzor
04-20-10 07:59 PM
Quick Reply: need help with a ignition turn on signal under the hood
