DIY: IS-F front brake rotors
Old 03-03-12, 07:13 PM
jleonard71
jleonard71's Avatar
I replaced my brake pads about 6 months ago because they were literally worn down to nothing, but I didn't replace the rotors (though I probably should have). Well now the rotors are so worn that I have lost a lot of braking power, and when I took off the pads and rotors to replace them I noticed that the rotors have huge recessed lips on both the inner and outer edges. And as such, they have caused the pads to have lips on the edges of the pads which stick out further than the rest of the pad. Will this hurt the new rotors if I install these pads with the new rotors? Or will the pads just wear down to flat after some heavy braking?
A prompt answer would be greatly appreciated since my car is completely taken apart right now!
Thanks!
P.S. I am using the Raybestos rotors which I picked up for just $348 for the set of all 4. I thought that was a hell of a deal since the dealer charges $1800 to install a set of OEM rotors, and these should be just as good!
Old 03-04-12, 08:33 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,838 Likes on 2,327 Posts
The pads will wear down and they'll work just fine.
Old 03-05-12, 07:10 AM
obby
obby's Avatar
awesome DIY.. will be printing this out for my next brake/rotor change.
Old 03-05-12, 12:59 PM
SpmMorrow
SpmMorrow's Avatar
great write up, thanks! Will definatly do my own in the future.
Old 03-05-12, 01:40 PM
anxiouz
anxiouz's Avatar
Subscribing. Very nice.
And even if the rotors still had life, I can't fault the OP for replacing them anyway. Better safe than sorry, especially if the car gets tracked.
Old 03-05-12, 08:46 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
The rotors don't get to 28mm then suddenly disintegrate even at the track. I've seen guys race with badly cracked rotors. I have tracked cracked rotors myself. "Better safe than sorry" does not apply here.
Old 06-01-12, 04:56 AM
ISFRacer83
ISFRacer83's Avatar
Here's a suggestion... I found the best pricing on OEM brake pads by purchasing the front from Sewell Parts, and the rears directly from Carson. Both with Lexus forum discounts.
PS- James, thanks for the help yesterday again.
Old 07-01-12, 05:43 PM
newguy1354
newguy1354's Avatar
Thank you to caymandive for this DIY thread. It was very helpful for me.
I changed the OE Brembo pads and rotors. I have been on the Hawk HPS pads and Centric Rotors I got from tirerack.com for a few hundred miles and a day at Texas Motorsport Ranch ( http://www.motorsportranch.com/1.7-road-course.cfm ). I ran the 1.7 mile clockwise and the brakes were definitely over powering the all season tires I ran on. So far this combo has been excellent. I have noticed very little brake squeal, better/smoother initial bite, and no fade yet.
I haven't have this car long but I'm already in love. Easier then I expected to work on and with 60k on the clock, perfect reliability.
Old 07-01-12, 06:12 PM
andysvette
andysvette's Avatar
Any concerns using these RockAuto rotors for track duty?
Old 10-07-12, 09:58 PM
ToothDoc
11 Second Club
ToothDoc's Avatar
If you guys don't own a torque wrench, I did noticed the two17 mm bolts that hold the calipers in place are marked with a yellow marker. Just keep track of which bolt went to which hole and torque them until the yellow marks match up again.
Also, the rear is identical except the bolts holding the calipers are smaller. One IMPORTANT difference is that the small rubber cover needs to be removed and you might have to loosen a small dial to adjust the emergency drum brakes so they're not stuck on the inside edge of the rotors or else you risk breaking the drum brake spring retainer like I did. hahaha It was a REAL pain to put back on.
Old 10-08-12, 11:27 AM
shyguyF
shyguyF's Avatar
Thanks Caymandive and SargeISF.
It is very helpful DIY brake thread,i just put new Wearever pads on my F, i like it so much for daily driving.
Old 07-06-13, 11:51 AM
550fresh
550fresh's Avatar
When u measure the rotors with micrometer do u put it on flat surface or in the cross drilled holes also what micrometer is that
Old 07-08-13, 12:35 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
The micrometer is a 1" - 2" deep throat (or frame) micrometer. Looks like a Mitutoyo combimike to me. The late model version of this is here:
http://store.greatgages.com/servlet/...-Throat/Detail
Measuring the holes would be pointless. Measure the flat surfaces.
Old 07-08-13, 03:30 AM
ISFNYC
ISFNYC's Avatar
Fantastic post!! I will definitely be following this when i need to replace my rotors +1
Old 07-08-13, 01:01 PM
550fresh
550fresh's Avatar
thanks for the help is there no need to bleed the brakes i got my rotors on amazon ac delco 90 bucks each
Quick Reply: DIY: IS-F front brake rotors
