Sikky header rattle passenger side.
just installed sikky headers on my '11. Passenger side was a really close fit to motor mount and has me thinking it would be a problem later. Sure enough, once started up there is a major chatter. Anyone have fitment issues with their Sikky headers? did anyone do the install themselves possibly have any insight on this?
motor mount under load because it gets worse when I put my car into any gear.
I've tracked my F, and also WOT here and there, no issues, no rattles. I had mine installed by JE. I was like there 13th install so I imagine they had good lessons learned. I say contact JE to ask. Good luck.
I installed my own headers and the problem areas are near the flanges that mate to the exhaust. At certain times depending on a lot of things I can make the flanges touch the heat shield studs on the main frame rails, causing a loud vibration. Another area of issue is when you reinstall the exhaust if you have a Joe-Z it could rub on the splash guard brace on the tranny. Yes the mount is really close to the header on the passenger side, but that will not cause a rattle unless it is actually touching all the time. And of that was the case I don't see how you could put the mount back in anyways. The header and the mount will move in unison because they are both secured to the block. It is the other end of the mount that has movement. If it is rattling as soon as the engine is started, that is an exhaust leak, not a rattle or vibration. It will sound like one, but that is the noise of combustion leaking where it should not. Take a video and post it here for group deliberation.
And if it gets worse when you put the car in gear that is because you are loading the motor and it takes more combustion than in idle. I say it is definitely a leak. Probably on the engine block.
thanks anyone who were able to try and help but I was able to narrow down the problems and fix them. passenger side 2nd runner was actually pressed against the frame ever so slightly and I'm having the steering shaft contact now though so I will be addressing that tomorrow.
just had my sikky headers installed and i have a huge rattle/vibration on the passenger side under full throttle and especially when the car is turning left under throttle. Sikky told me to just try and "massage" the header to fix the problem. Anyone try this yet. Really disappointed with the product so far.
