This is how I got rid of the drone on my Joe-Z exhuast
Old 02-13-13, 04:38 AM
  #46
Compthis
Compthis's Avatar
Originally Posted by DS2k
I basically got a local shop to fabricate end pipes with stock mufflers. The switch between the two setups is as easy as lifting the rear end of the car and unbolting 4 bolts. The drone is COMPLETELY gone, and the noise level is very comparable to the stock setup.
I will have to do some dyno runs to document any change in power, but they only run I have with this setup didn't look promising, but that's mainly due to the K&N drop-in filter I had installed at the time.
Are you saying the simple K&N drop in filter was hindering the performance of your vehicle?
Old 02-13-13, 06:27 AM
  #47
DS2k
DS2k's Avatar
From what I was told, the K&N filter had fouled my A/F sensor which could have contributed to the loss of power.
Old 02-18-13, 06:33 AM
  #48
Compthis
Compthis's Avatar
Were you throwing a CEL or was it solely what this guy thought?
Old 02-18-13, 07:57 AM
  #49
DS2k
DS2k's Avatar
no CEL, but the sensor had definitely 'dirty' when I pulled it out for cleaning. My money is still on the oem mufflers not being as high flowing as Joe-z's
Old 02-18-13, 08:02 AM
  #50
DS2k
DS2k's Avatar
Originally Posted by RecursiveL
I'm quite torn between doing this muffler mod and just putting the stock exhaust back on. I've got the Borla catback and while I like the sound, the 2k RPM drone just kills it for me. I've done everything, sound deadening material, added venturis which helped, but it's still there.
Personally, it kills the dual nature of the car for me to have that drone. Does putting on the stock mufflers back on eliminate the drone?
the drone is completely eliminated, but so are any meaningful HP gains based on the dyno run with this setup. It's currently my "winter" setup since the noise level is much more bearable (and enjoyable) for me in the summer time when I have the windows cracked open.
NotnFsport
GS F (2016-present)
16
02-21-18 02:30 PM
idoke1
IS F (2008-2014)
03-17-15 04:03 PM
DOHCZ34
Performance & Maintenance
27
07-30-07 05:30 PM
Sleeper97
35
06-08-05 12:51 AM
es30000
06-10-03 10:52 AM
Quick Reply: This is how I got rid of the drone on my Joe-Z exhuast
