Figs Engineering Mega Arms & Toe Links Installed (Lexus IS-F)
Old 10-21-11, 10:22 PM
meade916
meade916's Avatar
Default Figs Engineering Mega Arms & Toe Links Installed (Lexus IS-F)
Already being a victim of premature inner tire wear from lowering my car, i turned to Club Lexus to see if there was a solution.....and i am happy to say i found the solution i was looking for. Figs Engineering adjustable lower control arms and toe links.....
I finished them this evening and it was too late to go get it aligned. I have an appointment on Monday..... We got them as close as possible using the old tape measure trick. The camber is all but gone now! FIGS FTMFW
ok here is the pics.
Old 10-22-11, 01:07 AM
kenysl
kenysl's Avatar
Does that offer handling improvement? In what aspect?
Old 10-22-11, 03:46 AM
MRISF
MRISF's Avatar
Yes ken your tire now makes full contact with the road instead of having just the inside make contact. More tire= More traction
Old 10-22-11, 08:53 AM
FIGS
The Maker
FIGS's Avatar
Steve, looks great.
To summarize for all the handling benefits:
MEGA arms
-Allows camber correction in the proper location, at the bottom rear of the suspension. This adjusts camber and toe and allows most aggressive tire and wheel fitments.
-Static offset via inner spherical bearing and on-vehicle adjustment via eccentric bolt. These are common adjustments that any shop should be able to handle. That means you can get away with lower labor on install and alignment.
-Removes staked rubber bushing on the inside with free locating spherical bearing. This removes one undamped spring component from the suspension and increases traction and suspension response.
-Adjustments for spring mount and sway endlink mount. This means you can center the shock in the spring when lowered, especially important for the KW application since it uses the factory upper hats and shorter lower springs. Sway endlink mount has 3 options to adjust sway influence and preload.
- Shifted total weight inward to increase response further. Dimpling and gusseting increase total stiffness while removing weight and increase suspension response further.
Toe links
-Allows infinite adjustment
-Pushes eccentric mount all the way in to maximize the toe link length. This reduce bump steer characteristics in the rear. This is the feeling the rear is steering when you go over a bump and the feeling of tucking in on hard cornering.
-Allows running more camber with mitigated tire wear for track days.
-Replaces inner staked rubber bushing with spherical bearing for removal of undamped spring and potential binding due to rubber preload.
A common question is how much extra noise is transferred due the to spherical bearing replacement. teh answer is that it is minimal since the rear subframe bushings are still the major filter in noise conduction to the body. So you get a drastic improvement without taking on extra NVH.
Any other questions feel free to post or PM.
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
FastAF (02-10-21)
Old 10-22-11, 09:11 AM
Linkseal
Linkseal's Avatar
^PM sent!
To Op, great work, please keep us update of your new camber/caster/toe settings after alignment.
Can't wait to hear some reviews after!
Old 10-22-11, 09:16 AM
tenspeed
tenspeed's Avatar
Nice job Meade!
I envy how clean your car is underneath. Cars in the NE only look that clean for a couple of months or a rainstorm - whichever comes first.
Old 10-22-11, 02:07 PM
KJH
KJH's Avatar
Steve,
You will love these. I've had 'em since FIGS first offered them for sale. Waiting on the fronts when they go on for sale. Good job, man.
Old 10-22-11, 06:21 PM
Linkseal
Linkseal's Avatar
Off topic a bit, but anyone knows what is the max rear camber when lowered on OEM arms?
Old 10-22-11, 07:01 PM
lukeisf
lukeisf's Avatar
What is the price
Old 10-22-11, 07:04 PM
hydralisk
hydralisk's Avatar
I would like to know as well. Running more camber would be great!
Old 10-22-11, 07:14 PM
CalitriSC
CalitriSC's Avatar
Looks really good man. I would like to get those at some point. So far I have no tire wear from being very low on my KWs. Went and got an alignment after the install and its been fine, tires still look exactly the same.
Old 10-22-11, 07:15 PM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
Originally Posted by lukeisf
What is the price
http://www.figsprops.com/suspension.htm
Lou
Old 10-22-11, 07:24 PM
FIGS
The Maker
FIGS's Avatar
Lou, actually the new site is shopfigs.com.
http://shopfigs.com/v1/index.php?rou...&product_id=55
__________________
Old 10-22-11, 07:27 PM
FIGS
The Maker
FIGS's Avatar
This will depend on how low you go. The lower you are the more camber you will have as well as toe in.
__________________
Old 10-22-11, 11:22 PM
ShadowISF
ShadowISF's Avatar
Looks good!
Quick Reply: Figs Engineering Mega Arms & Toe Links Installed (Lexus IS-F)
