Borla Exhaust hanging low
Old 08-31-14, 11:35 AM
jadeboy
jadeboy's Avatar
Default Borla Exhaust hanging low
Don't know if this is normal.. but I had another ClubLexus member compared his stock exhaust (which I can't even see from the back) and the Borla Exhaust.
It's seems Borla Exhaust is hanging low compare to stock, is this normal?
I have my car lowered and having this exhaust this low has cause a few issues with going over speed bump.
Note: the muffler hangers are in attached and in place.
Old 08-31-14, 01:51 PM
I8ABMR
I8ABMR's Avatar
not sure if its normal but it does look low to me. I had a borla on my lowered G35 and dented it badly when I drove a shredded tire. Borla did replace for free under 1,000,000 mile warranty. Im sure the Borla owners will chime in. we need another member to match this photo so we can compare directly
Old 08-31-14, 04:30 PM
Lmood
Lmood's Avatar
Here's mine.
So yes I'd say its a tad low.
Old 08-31-14, 05:22 PM
ISFPOWER
ISFPOWER's Avatar
check the hanger in the middle of the car, i dont think its attached correctly
Old 08-31-14, 06:04 PM
jat0223
jat0223's Avatar
You have to make sure that the pipes from the mufflers align with the diffuser tips. After I installed mine I realized that the pipes from the left muffler were pointing slightly up (the back of the muffler hanged low and so did the pipe). I just unscrewed the bolt/clamp, pushed that pipe up and tighten the bolt/clamp again. After that, everything aligned perfectly and the pipe didn't hang that low.
You can even see it in your picture how the back of the left muffler is hanging lower than the right one.
Old 08-31-14, 06:38 PM
USB_F
USB_F's Avatar
what are you lowered on?
Old 09-01-14, 12:27 AM
jadeboy
jadeboy's Avatar
There is 1 attached exhaust hanger in the middle, ISF comes with 2nd hanger but Borla does not support 2nd hanger in the middle.
jat0223 would you post your Borla setup.
Old 09-01-14, 12:33 PM
jat0223
jat0223's Avatar
Here's a picture of mine.
Old 09-01-14, 02:34 PM
v8sten
v8sten's Avatar
does it wobble to and fro
Old 09-02-14, 02:10 PM
USB_F
USB_F's Avatar
Borla was definitely an easier install than Joe Z.
Chiubacca
02-29-16 08:52 AM
Sexy_Lexy
Performance
02-03-08 07:18 PM
QikSilvr
Performance
05-21-06 07:53 AM
UTGS400
Southwest
03-21-06 02:02 PM
Kharizma
Performance
05-07-05 08:22 PM
Quick Reply: Borla Exhaust hanging low
