LED in Gauge Cluster
^^^ What a bad luck! I'd give it a try and go to the dealer, they may fix it for you at no charge.
I've gone through the same list you have up there except the squeaky brakes. On top of that I got a call from the dealer today letting me know that my car is ready for pickup, water pump and front caliper were replaced under warranty. I hope this is it because I'll be out of warranty in 800 miles.
Sorry JLeonard, I would be pissed too if that happened to me...If the cost is too high to replace out of warranty, you can turn the dimmer down all the way as another member posted. I tried it and it isn't bad at all but I think if the dimmer is down all the way, the car wont dim the nav during the day/night.
On a lighter note though, the dealer did say they would order me in a new gauge cluster covered under warranty. I however held off on it for the time being because they had to keep the car for at least 5 days. I am going to go back to the dealer and get it done soon. Thanks juanca for your input. Do you think I can get a 2011 cluster in there or is that not possible? I know many don't like the new cluster design, but change is good sometimes.
Hey Juanca, I'm going to respond in the other thread too but wanted to let you know that the dealer did look at my caliper peeling as well. He didn't say what the procedure would be for it but he did say that they would take care of it as well.
Sorry to revive such old thread but I too am having similar issues. About 5 months ago my subwoofer was also replaced under warranty. Now my nav screen went out as well as my cluster needles having dead pixels. See pictures below- btw I have the nav override and vaistech sl2vi but I dont think that's what caused the nav screen to go out. #bummer
For those of you with the LED needles going out AND are still under factory warranty, the entire instrumentation panel will be replaced. Dealership will keep the car to get the new IP programmed with your current mileage.
If you are out of warranty, you will need to buy a cluster and replace it at your own cost.
I owned an IS350 with this issue, and now an ISF that has the same issue. IS350 was out of warranty and had to purchase a used IP off of eBay. ISF was still under warranty and replaced without hassle. I asked the service advisor how much would it be for a new one OUT OF WARRANTY and was around $1800.
List of 2008 ISF parts that failed and replaced under warranty:
- NAV screen not responding to touch inputs, replaced entire NAV screen module
- Water pump leaking, replaced
- Tach needle LED dead, IP replaced
I am out of warranty now, over 50k miles, and didn't purchase the extended warranty. Hopefully all the replacement parts will hold up for a few more years.
Anyone know if this is something that would be covered under the platinum extended warranty? In the warranty details is says everything is covered except for things which are specifically excluded, and I don't see the gauge cluster anywhere on that list.
If you are still under factory warranty go get the extended aftermarket warranty because it is a Lexus it is pretty inexpensive. Mine was $1500 when I bought the car and covers me for 8yrs 100K miles! If you are out of warranty it will be a little more expensive but shouldn't be much.
If the gauge is the only thing that goes out under the extended warranty it's already paid for itself.
Add another 08 to the list. I have the tach needle with a dead area. Sometimes its fine with warm weather and the whole needle is blue. But most of the time now, the needle just has a nice big dead area.
Maybe I will try to take it in and have them fix the car along with the random knocking issue that I am also having. Hopefully I am not raising a post thats too old. I did a search...this is what came up.
Hey guys,
It's unfortunate that these gauge clusters are already having issues. One issue is the needle movement. Jerky gauges, stuck gauges, etc. We can help!
We can also take care of any lighting needs. Even the backlighting!
We can do the tach/mph needles in blue, white, red, dark green, others by special request..
We can do the temp/fuel needles in blue, red, pure white, green, purple, orange, yellow, amber, warm white, cool white
Here is a picture of an IS250/350 we just completed.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
I tried to explain this to my sister. She doesn't get it.
