2008 Lexus IS-F with clearance issues
Old 08-03-11, 12:52 PM
HITMAN6566
HITMAN6566's Avatar
Default 2008 Lexus IS-F with clearance issues
I recently purchased a 2008 IS-F with approx 37k miles and still under Manufac. warranty.....it has 20" GNOSIS wheels and tires are :
front: 245/30/ZR20
rear: 285/25/ZR20
I am having issues with clearance and needed advise on changing tires without changing the wheels.
Thanks
Rafi
Old 08-03-11, 04:06 PM
Dv8tion388
Dv8tion388's Avatar
front: 245/30/ZR20
rear: 285/25/ZR20
Thanks
Rafi
Your not going to change much with the tires. What clearance is having issues?
~Dv8
Old 08-03-11, 04:10 PM
CalitriSC
CalitriSC's Avatar
Not sure why you are having issues. I have 255s/295s
Old 08-03-11, 05:24 PM
iffy08
iffy08's Avatar
That's interesting. I have 285/30's in the rear and I figured moving to your tire size in the rear would fix my issue. Be more specific, where are you having issues?
Old 08-03-11, 06:06 PM
slowIST
slowIST's Avatar
What are the widths and offsets?
Old 08-03-11, 06:54 PM
flowrider
flowrider's Avatar
Received 1,948 Likes on 1,371 Posts
Bingo!!!!
Lou
Old 08-03-11, 08:17 PM
BLKFIN
BLKFIN's Avatar
Did you buy the silver one from Texas Import Sales? If so, that was a forum members car and I do believe it was lowered. You are going to need to change out springs to raise it up. By putting larger tires you will just rub and not solve the issue.
Anyway congrats on the new ride!!
Old 08-04-11, 12:41 AM
primecut
primecut's Avatar
Hmm. yea sounds like it's bigmike's(sp?) car. Does it also have the Lexon front lip on it? Perhaps you are having ground clearance issues with the front and want to sell me the lip?
I'm guessing by clearance you mean there is rubbing... If you want to keep the setup as-is, then just go to a tuner shop and have them shave or roll the fenders a bit more. Otherwise, that's how it is... gotta pay to play, buddy.
Old 08-04-11, 06:46 AM
flowrider
flowrider's Avatar
Yep, sounds like Mike's car. Is this it?:
https://www.clublexus.com/forums/is-...f-on-ebay.html
If this is it, and I'd bet it is, the OP has a lot of reading to do to learn the car's pedigree
Lou
Old 08-08-11, 08:13 AM
HITMAN6566
HITMAN6566's Avatar
Yes it is the one from Texas Import Sales.....just got it a few weeks ago....I paid 45k for it with 37k miles.....good deal?....issue is with front end rubbing the driveway.....recently removed front lip diffuser and has helped a bit....will look into changing springs....any idea the cost of doing this?
Old 08-08-11, 09:38 AM
Evil Teo
Evil Teo's Avatar
I had the same problem leaving my driveway but not anymore since I go through from an angle now.
Old 08-08-11, 12:12 PM
BLKFIN
BLKFIN's Avatar
Sounds like a good deal for that car. I will buy the lip off of you...my car is silver as well and I am local. It should not be real expensive to get the springs switched, I am sure there is someone on the board that has some stock springs they would sell.
Let me know about the lip~
Luxotic
Lexus Vehicles Classifieds
10-10-16 12:08 PM
UniqSC
06-28-16 05:57 AM
Gee2anIS
10-15-15 03:51 AM
chikken
IS F (2008-2014)
04-13-08 10:45 PM
Quick Reply: 2008 Lexus IS-F with clearance issues
