A pillar cover removal?
Old 05-09-11, 04:28 PM
infinus
infinus's Avatar
Default A pillar cover removal?
How do I remove the cover for the A pillar? At the top its attached with a short plastic tie so I can only get it partially off and at the bottom I have no clue how to detach it. I want to make sure the wiring I ran through there is clear of the airbag at the bottom it looks like it crosses over and I don't want it impeding it in case of an accident.
Where it crosses under the airbag.
The area I'm trying to get to.
The top
Old 05-09-11, 05:24 PM
ming15237
ming15237's Avatar
The top
This should just slide up and out from there now that you have the clip pins pulled loose from the a pillar.
Old 05-09-11, 06:07 PM
infinus
infinus's Avatar
But it's not fully detached it's hanging from a little black strip at the top. Do I just pull really hard to detach it? I don't want to break it.
Old 05-10-11, 04:52 AM
ming15237
ming15237's Avatar
my diagram is showing one plastic clip (white in your picture). the black plastic L shaped tang is meant to guide the A pillar cover upwards if the bag deploys. is should be slotted at to allow the pillar cover to go slide up towards the ceiling. Hope this helps.
Old 05-10-11, 08:52 AM
Dv8tion388
Dv8tion388's Avatar
Its like a "T", I snipped the tip off. It still goes back in flush and tight. You need a unique tool that I found isnt nessasary if you just want it off.
Im pretty sure they designed it like that in case of an accident when the airbags deploy the pillar doesnt go flying.
~Dv8
Old 05-10-11, 10:04 AM
yemgi
yemgi's Avatar
Here is a diagram:
Old 05-10-11, 10:43 AM
infinus
infinus's Avatar
Awesome thanks for the help everyone.
Old 05-10-11, 01:28 PM
hwy1isf
hwy1isf's Avatar
What are you doing if you don't mind me asking?
Old 05-11-11, 01:05 AM
infinus
infinus's Avatar
Routing the power wire for my valentine one.
Old 05-11-11, 01:50 PM
hwy1isf
hwy1isf's Avatar
I connected my V1 to the rear of the mirror, and used an under mirror mount.
Old 05-12-11, 12:38 PM
infinus
infinus's Avatar
I have the under mirror mount also, I love it! I had it on my G35 and luckily the ISF has the same mirror. I just didn't want to mess with splicing wires and I couldn't find my torx bit's to get the mirror off so I just ran it down to the drivers side fuse box.
7akata
SC- 1st Gen (1992-2000)
09-06-11 07:47 PM
icegoffy
Hybrid Technology
04-13-11 05:04 PM
Cannonbear
07-13-05 09:25 AM
Ryan
06-12-02 09:43 PM
Quick Reply: A pillar cover removal?
