Front isf camber?
Old 04-01-11, 05:30 PM
michaelisf
michaelisf's Avatar
Default Front isf camber?
Does isf have a problem like the is 250 and is 350 they don't make front camber kits.... Do they make camber kits for isf?
Old 04-02-11, 10:44 AM
Evil Teo
Evil Teo's Avatar
nope, nothing is out so far but i believe figs might be working on something for our cars. pm him.
Old 04-04-11, 02:35 AM
flipside909
Lexus Connoisseur
flipside909's Avatar
Yeah unfortunately there are non. The natural geometry of double wishbone suspensions. The ISF and the ISx50 share the exact same suspension components. They only difference are the shocks, spring rates and bushings between all the models.
Old 04-04-11, 07:49 AM
michaelisf
michaelisf's Avatar
Thx bro wheres 909 area? Hawaii?
Old 04-04-11, 10:56 AM
flipside909
Lexus Connoisseur
No prob. Google it.
Old 04-14-11, 08:59 PM
FIGS
The Maker
FIGS's Avatar
I have made some proto arms, but unfortunately you will get no camber correction with the upper A-arm. There is no clearance to push it out substantially as the inner fender sheetmetal is form fit to arm perfectly. Here is a pic. They will mostly be for caster correction as well as more neg camber if desired.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Piciu
IS F (2008-2014)
25
01-28-17 10:13 AM
FIGS
Suspension and Brakes
25
03-12-11 07:43 AM
isbeater
IS F (2008-2014)
04-28-10 01:10 PM
HEWITT
IS F (2008-2014)
08-14-09 12:28 PM
Quick Reply: Front isf camber?
