Frustrating first 621 miles
Well I have had my F now for a week and while I absolutely enjoy driving it I made the ' mistake ' of reading the manual. In the section on breaking in the engine it states that one should not attempt sudden accelerations or stops for the first 621 miles(1000 km) This is so frustrating because I am so tempted to push the pedal.
Did everyone follow this caution or is it just the usual manufacturer disclaimer?
Is it necessary to break in the engine in modern cars?
I think you should follow the manual's advice. It could save you from adding oil every time you fill the tank. Just take it easy and vary the speed. Many people dump the break in oil around the 700-1000 mile mark too. Maybe it's being over cautious but why take a chance.
I let my wife broke it in. Bad mistake...she didn't want to give the key back.
everyone told me it was a myth that you had to "granny it" from like up to 500-1000 with new cars these days, engines pretty much come broken in for the most part. Yur almost at that point anyway, take a long drive for an hour or so, then yur ready to PUNCH IT!
When I got my F a few years back, I was driving as slow as some of the senior citizens in my area. I think after 1000 miles logged, that first WOT was sure worth waiting for. I've seen some new owners right after getting the keys from the salesman and just full on flooring them. Not the best thing, but it's their car and decision to deal with. I'd say just stick to the break in period. Enjoy the car!
I have about 700 miles on mine now. I am guilty of opening it up before the break in period. We're not talking at every chance but bursts for sure. I would hope that the motors go through testing before leaving the factory and I'm not talking baby testing them.
I'm going to have my first scheduled maintenance done this week and then to the track to do some baseline runs.
Tech Info Resource
I ignored the recommendations. I have 45k or so on mine now. It does not use oil, used oil analysis does not indicate any abnormal wear, and it continues to make very good power.
After building a fair number of engines, I don't believe the manufacturers are concerned about what is best for the owner, I think they're concerned about warranty claims.
There are other parts of the drive train that may benefit from restraint, but the engine isn't one of them IME.
Some comments on what I usually do are here:
http://www.mbworld.org/forums/w211-a...ave-asked.html
http://www.6speedonline.com/forums/t...ine-break.html
And another guy who does it similarly:
http://www.mototuneusa.com/break_in_secrets.htm
Drive the car, make it work, it will be fine.
I'm w/ Lobux... I break them in 'aggressively'... but 'shift slowly'... it is typically drive train and brake parts that need 'break in'... My recommendation would be to possibly not use the 'Sport Mode'... as that's the only way to 'slowdown' the shift... other than that... have fun and enjoy em!
Dave
Dave
The Pre Delivery Inspection Tech probably ran it harder in it's first couple of miles than you will have ever! I'm with Lobux, run it hard from the start. I myself have run everything from brand new motorcycles, cars, and freshly built engines hard from the get go. Don't hold back and enjoy!
Ran our ISF strong from day one and it has been rock solid with no oil usage. Its not like these engines are not ran at all from the factory, as I am sure they have a short break in from the factory to check operating temps and for any leaks like oil. Drive it like you want to but just change the oil a bit sooner for your first oil change. .
My car has ~600 miles now and it was driven semi-hard.. though never quite at WOT, varying rpms and light throttle when cold.
The plan is to attend some track/autocross next month, the car will probably have 1.5k miles by then. Should I change the oil before the event or not worry about it till 5k?
break in
Was at the corvette factory in bowling green kentucky last summer .Great tour of the plant , and at the end of the line when they first start up the vette's , they quickly run into the dyno area and run the cars at about 80mph at least six times until they adjust the limiters . So why pamper the car ?
