Nitto NT555
Nitto NT555
Decided to get a new set of Nittos on the F. I've been using these on my G35 for years. They've lasted me 22,000mi+ on 2 degrees of Negative camber with multiple trackdays and autocrossing on each set (no rotations cause i'm lazy and absent minded).
Nitto NT555
Front: 245/35
Rear: 275/30
Performance Rating: W
UTQ: 300
Random Musings: When properly inflated, the tires exhibit no sidewall rollover or corner tread block "Chunking." Predictable breakaway, no squealing. Good Wet performance unless there is standing water.
Nitto NT555
Front: 245/35
Rear: 275/30
UTQ: 300
I read through some of the tire threads that were going on here, but they seemed to be more focused on ultimate performance and i needed a balance of performance/Longevity/price. I actually ordered a set of General Exclaim UHP and then got the call they were discontinued. These are kinda my fallback tire since they have served me well on the G.
Nobody had really mentioned or commented on them in here so i thought i'd throw them in the ring.
Perhaps they are a great value for the money but I consider them average in performance in the dry. I definitely think they will seriously compromise the performance of the F.
Tech Info Resource
555s have been around a long time. I haven't personally owned a set, but I remember lots of Supra owners running them back in the days I was running S-02s. They were cheaper to buy but not cheaper to own as they didn't handle as well and they didn't last as long.
FWIW, in the "economy" department, I remember a back page shot in C&D from years ago. There was a Ferrari in the ditch with a caption "Good tires, but not GREAT tires..." Since tires are the only thing between you and the road, they determine your ultimate safety in the car.
Tech Info Resource
On the street no. On the track, they'll be close, very close. I have no complaints with the OEM Bridgestones on the street or track - they're predictable, work well until they are past the wear bars, and they give very respectable mileage. I'm certain the PS2s will give a slightly better lap time, but you'd never know the difference driving on the street.
You said longevity was a consideration - I got 31k out of my original Bridgestone rears including three track weekends at Carolina Motorsports Park with each weekend totaling 4 hours on course. I don't see how you wouldn't consider them a bargain. The fronts would have lasted just as well, but they corded on the inside edge long before they were out of tread in the middle at 21k miles.
As you stated, the 555s have been around for a long time. They probably aren't the most technologically advanced tire out there, though i'm pretty sure there have been compound changes over the years. But, there is a reason they have been around for a while. Bad reviews of these tires are few and far between.
Funny you should mention the safety issue. I had to take evasive action to avoid hitting javolina in the road at 3am in 27 degree weather at 70mph recently. These things were in my lane. The car swerved effortlessly and with no drama around and right back into the proper lane. The tires proved themselves.
I am aware that there are many better options out there. Better is a relative term. I would never suggest using these as a dedicated track/autocross tire. If people are serious about competition, they need to get a more serious tire.
Tech Info Resource
The stock tires can't be rotated, so there is nothing that could be done to prevent the front tire wear issues. Even with the toe set at zero, I'm guessing you'de be hard pressed to pull 30,000mi out of the fronts. My rears we're also pretty good after 27,000mi, but i figured it would be a good time to move to something else. With the Nitto's, i know through experience that they will last through the abuse i put them through. With proper rotation (swapped off the rim across the car), i may even be able to get 35,000mi to 40,000mi out of them.
Take a peek at this thread. I'm tracking front wear and settings with photo updates.
