Interest thread, 2-Piece front rotors and rear rotor options
Tech Info Resource
What's the purpose of the countersunk hole in the hat? We don't have anything to retain these rotors on our stock hubs. Is this to provide an option - drill and tap the hub for a retaining screw?
Slots only?
Slots only?
Tech Info Resource
I just put on a set of cryo'd OEMs on the front. Amazingly they seem to dust less with the OEM pads. But yeah, I'd be keen on these if it weren't for brand new on the car. I'd rather spend the money on the Penskes...
Lobux and all, the pics are for demonstration only. We stll need to get first parts in at which point we will post those pictures up. However the stock rotors have a push-out threaded hole in the rear and this feature will be reproduced.
The rotors are "open slot" only. This is Racingbrakes patented slot pattern and will assist in cooling..not just cleaning like a typical slotted setup.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
all pricing is on our site. This is not the order thread but rather the interest log thread so I do not want mods to move it based on order info content. Discount is another 10% off.
__________________
yep, and they are nearly $2k just for the front. Our are going to be significantly less than that plus we will all 4 corners. Not to mention the center mounted rotor hat is far superior to the single side mounted hat for cooling and uniform thermal expansion.
__________________
5 Sets of Front Rotors now in house. We will verify and test and then release.
I guess no one wanted the extra pre order discount.
Rears are still a few weeks out.
Fig
Fig
__________________
For the pair sir. There is still a discount, the preorder was just on top of that.
__________________
