What oil to use in rear-diff?
Old 12-02-13, 08:32 AM
  #31
4TehNguyen
4TehNguyen's Avatar
heres crush washers for an 06 IS350, Part #: 1215710010. Its probably the same thing
http://is.sewellparts.com/accessorie...2006/1903.html
Old 07-29-14, 05:40 PM
  #32
itsmike177
itsmike177's Avatar
Just changed the rear diff fluid on a 2011 ISF at 29,900 miles. Replaced it with Redline 75W-90 GL5 rating.
The magnet on the drain plug had a nice gooey layer of shavings, and the diff fluid color was a little bit dark red going on black.
If you drive hard and power out of corners a lot (ISFs with torsen LSD,) I would recommend changing it at 30k or earlier. I think changing it at 60k is a little too long.
Old 07-29-14, 06:24 PM
  #33
scamsel
scamsel's Avatar
how does one 'inspect' the rear differential oil to know it needs a changin'?
is it a tricky change out?
Old 07-30-14, 05:50 AM
  #34
Compthis
Compthis's Avatar
Don't bother inspecting it. If you know you have been rough with the car or have 40000miles on it, replace it. This is for 2008 to 2009. I think the diff with LSD (2010-2014) requires replacing earlier. It's an easy job, drain from the bottom and fill on top until the fill hole spills over. Keep in mind, the fluids for non lsd and with are different.
Old 07-30-14, 05:52 AM
  #35
4TehNguyen
4TehNguyen's Avatar
make sure you open fill port first, you dont want to drain it first and find out you cant open the fill port for whatever reason. General statement for changing fluids. You can get Mobil1/Valvoline 75W-90 synthetic diff oil for $10/qt
Old 07-30-14, 06:51 PM
  #36
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,847 Likes on 2,332 Posts
Originally Posted by Compthis
...Keep in mind, the fluids for non lsd and with are different.
Not true. Torsen units use the same oil as an open diff. Any GL-5 is fine for either of them. It's the clutch type units that use a different oil.
Old 07-30-14, 08:25 PM
  #37
Compthis
Compthis's Avatar
I could be wrong but i thought the part number for the 2008 and 2010 diff fluid is different.
Old 07-31-14, 05:29 AM
  #38
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Somebody is trying to make you pay more for than you need. Any GL-5 gear oil is sufficient. Even the weight isn't a big deal for street applications. If you are tracking or drag racing, then you might want to consider a premium oil designed for shock loads, but for normal street use, it's not a big deal at all.
Old 01-13-18, 09:49 PM
  #39
allst4risf
allst4risf's Avatar
any one have a good brand of diff oil they recommend for 2012 plus isf? every one states to just fill the differential from the upper left (my right) portion and just let it over fill? how many quarts do you think is need for isf 2012?
Old 01-13-18, 10:19 PM
  #40
j3ff
j3ff's Avatar
Originally Posted by allst4risf
any one have a good brand of diff oil they recommend for 2012 plus isf? every one states to just fill the differential from the upper left (my right) portion and just let it over fill? how many quartz do you think is need for isf 2012?
your fill procedure sounds accurate to me. That's how I did my is350 diff fluid change; I used Redline.
The service schedule on the lexus site doesn't mention diff fluid change anywhere but I see a lot of us have done it. Are we changing as a preventative measure? My11 BTW.
Old 01-14-18, 04:05 PM
  #41
lobuxracer
Tech Info Resource
lobuxracer's Avatar
1.7 quarts. Any GL-5 oil will do. I ran Redline in mine before I put the OS Giken LSD in it. Now I run Giken's oil exclusively.
Old 01-20-18, 01:19 AM
  #42
1wrenchguy
1wrenchguy's Avatar
Curious are you running a OSG diff? Will the 80W-250 be too heavy for my stock 2012 diff? I was about to pull the trigger on my 60K with Motul Gear 300 LS. I noticed that there is also a regular Motul Gear 300 (non-LSD). Perhaps Motul GEAR FF 75W-140 (LSD) could be an option as well? http://speedfreaksusa.com/i-12012852...l-1-05-qt.html
I'm starting to get OCD like I do on my FZJ80, Ha! Thanks Lobux!
Old 01-20-18, 01:47 AM
  #43
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Yes, I am running the OSG spool. Otherwise I'd keep running Redline in it. There is no need for LS oil even if you have the Torsen. LS oils are made to work with clutch type limited slip spools only. You will gain nothing by running an LS oil in a Torsen as they are completely gear operated. Also, because these units are typically delivering a 500k mile service life, there's no point in exotic oils unless you are drag racing or doing some other kind of shock loading that might cause premature diff wear. There was zero discernible wear in my open diff when I put the Giken TCD in, and I'd only changed the oil one time.
1wrenchguy (01-20-18)
Old 01-22-18, 10:06 AM
  #44
Stingraygt
Stingraygt's Avatar
Good info on this thread.
Old 01-22-18, 10:30 AM
  #45
Weapon F
Weapon F's Avatar
Me? Probably will change at 50k intervals. I drive on the track. It's a bit more arduous than street duty.
So Lance, my 2011 with 85k with No issues no leaking etc Spirted driven daily driver what would you recommend? Top off with fresh oil if needed and call it day or just change out with fresh oil. And would you do same for tranny oil as well?
Thanks
David
Quick Reply: What oil to use in rear-diff?
