Side Skirt Help *pics*
Old 03-26-10, 01:11 PM
grumlenz
grumlenz's Avatar
Default Side Skirt Help *pics*
Hello, I don't know what the piece is called that comes up onto the front fender just below the "F" logo, it's all connected to the side skirt so I will use that. On my driver side there is a small gap where the top part meets the fender. Passenger side is perfect. I have added a couple pics. Does anyone know how that piece is secured and how I may be able to get rid of that gap. Is there clips behind it or what? It's barely noticeable but I am a perfectionist! Thanks
Old 03-26-10, 01:14 PM
iKenn
Just call me "Sprinkes"
iKenn's Avatar
If you never touched that part for any modding I say take it to the dealer.
Old 03-26-10, 03:02 PM
HyperMKIV
HyperMKIV's Avatar
it's held on by plastic clips in the back...
you can tug on it and it'll just pop off
the clips are probably loose behind it...
er...maybe i should say "tabs" instead...
Old 03-26-10, 05:39 PM
grumlenz
grumlenz's Avatar
Thanks! So do you think I should "tug" on it and get it loose then just make sure the clips are tight and snap it back? I just don't want to break anything
Old 03-26-10, 05:48 PM
HyperMKIV
HyperMKIV's Avatar
i just went to look at it...
there's 10mm bolts on the inside fender, you might want to take those out first...
i remember pulling mine off (to put he LED on) and it came off pretty easily...
Old 03-26-10, 05:52 PM
grumlenz
grumlenz's Avatar
Was just looking at mine and saw the bolts as well. I will unbolt it and then see what I can do. I appreciate your help!
Old 03-26-10, 06:14 PM
HyperMKIV
HyperMKIV's Avatar
good luck!!!
bcabano
11-27-18 05:43 AM
LexusRCF15
RC F (2015-present)
09-12-15 09:19 AM
zinzan
SC- 1st Gen (1992-2000)
05-23-12 08:14 AM
filthyLS4
02-02-12 08:15 AM
Quick Reply: Side Skirt Help *pics*
