This Forum is Sponsored By:
Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS-F
Thread Tools Display Modes
Old 11-20-09, 06:05 PM   #1
Galaxy 40
Trader Score: (0)
Galaxy 40's Avatar
Default IS-F Big Throttle by Think Design
What does this do?
Thanks
http://www.think-design.jp/exshopm.c...&kago=&dptype=
__________________
Galaxy 40 is offline   Reply With Quote
Old 11-20-09, 07:00 PM   #2
chrisburke
Trader Score: (0)
hmm void the warranty?? haha
chrisburke is offline   Reply With Quote
Old 11-20-09, 07:17 PM   #3
PHXF
Trader Score: (0)
Quote:
lol
presumably bigger is going to let more air in...which would make more power if the oem throttle was the bottleneck.
PHXF is offline   Reply With Quote
Old 11-20-09, 07:19 PM   #4
verals05
Trader Score: (0)
There's another thread floating around here or on LexusF.com and I believe they claimed about a 5-10hp gain...
I'm sure its a pricey item too, but Think Design does make quality... you get what you pay for.
verals05 is offline   Reply With Quote
Old 11-20-09, 08:40 PM   #5
ISFer
2008 Lexus IS-F
Trader Score: (0)
ISFer's Avatar
Quote:
Originally Posted by ISFAIL View Post
linky no worky
Link works here, and it's 68250 yen.......I'm guessing about $600 USD.
I wonder if it really is worth 5-10hp????
C.
__________________
'08 IS-F Mercury Metallic/Charcoal
Carbon Fiber B&C-Pillars...Jason Burtman Ind||Carbon Fiber Trunk Emblem||JoeZ PTS True Dual Exhaust||JoeZ intake||Tom's Super Street Airfilter
ISFer is offline   Reply With Quote
Old 11-21-09, 08:42 PM   #6
FIGS
The Maker
2008 Lexus IS-F
Trader Score: (2)
FIGS's Avatar
Send a message via AIM to FIGS Send a message via MSN to FIGS
typically TB's will give better throttle response, more air into the plenum faster. HP may come at peak, but you may lose low end torque. For instance, I now have dyno proof of the wide open secondary intake path losing power over the stock 2-stage intake path in the low end. When will we get an ITBL setup...that would be the best by pushing the throttle plate closer to the valves
__________________
<a href=http://www.figsengineering.com target=_blank>
Making Lexus Aftermarket parts since 2001
- Hood Prop Kits - OEM Replacement Struts (LS430, LS400) - Carbon Fiber Splitters - CNC Battery Bars - CNC Mat Saving Foot Plates - Camber Correction MEGA Arms - BC Racing Coilovers - Clutch Damper Delete
CURRENTLY IN DEVELOPMENT:
ISF PrePreg Carbon Engine Cover- ISF Ti Exhaust - ISF Custom Grill Insert- Rear Exhaust Tip Diffuser-
IS300: Gen2 Mega Arms - Front RCA / HiSteer - Heatshield
GS/SC 3/400: CF Hood Struts
FIGS is offline   Reply With Quote
Old 11-22-09, 01:28 PM   #7
K3RRY
Trader Score: (1)
icode makes 2 available upgrade options. Since there are 2 manufacturers producing them this upgrade SHOULD make a difference. icode states +5 ps/5hp increase, with an upgraded intake and a more free flowing exhaust this should definitely yield more than 5 hp.
1.
2.
__________________
'08 /212/ IS-F
K3RRY is offline   Reply With Quote
Old 11-22-09, 01:36 PM   #8
K3RRY
Trader Score: (1)
a little off topic but there's also a ecu reprogramming to sharpen the trans shift, map, throttle response, and speed limiter delete. +20hp
http://translate.google.com/translat...ial%26hs%3D14d
__________________
'08 /212/ IS-F
Old 11-22-09, 05:41 PM   #9
Juanca
Trader Score: (0)
Juanca's Avatar
It makes sense, last year I reported that my times were slower when using the secondary intake wide open, at the 1/8 mile I lost 2 MPH and my times were about 0.2 seconds slower. This was done in the same night, back to back runs.
Quote:
__________________
Juanca is offline   Reply With Quote
Tags
18, 250, big, design, intake, is, isf, lexus, lexusthink, mile, options, stage, throttle, turbo, upgrade
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Go
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
