transmission fluid check
As the title says, does anyone know how to check the tranny fluid?
I'm used to doing my own checks and can see no means to do so.
I noticed in the manual that it suggests seeing the dealer to get this done but I'd much rather do it myself on a more regular basis.
Cheers and TIA.
C.
Cheers and TIA.
C.
Under normal operating conditions, the fluid should be inspected via the fill/drain plug, level surface, and warm fluid. I recommend checking the fluid at least once a year or every 15k miles, which ever occurs first.
Based on the information I have gathered since '05. The main reason for the sealed transmissions has been due to misinformed consumers placing the wrong transmission fluid in their transmissions.
Toyota/Lexus considers "WS fluid" to be a lifetime fluid.
i had accident while back they had to put some more tranny fluids in for my car at the dealer.
from what i heard, Tranny Fluid only can be accessed from underneath the car and they have to be at about 95 degrees. once they open up both bolts on the tranny they fill up the oil from one side until it drops from the other side. or something.. i dont know what they do exactly... but its some idea...
Tech Info Resource
Setting the fluid level is a PITA and has it's own special procedure and it's own SSTs. Without the Techstream tool to plug into the car it's a bit of a challenge just getting the fluid to the correct temperature unless it's summer in the desert.
ive been to them for service 3 times
and 3 times they have screwed something up
never going back
too careless
watch out for the oil being overfilled
happened twice now
i should be able to leave my car with them and get it back better then i left it
and this is far from reality with them
never going back
too careless
happened twice now
Tech Info Resource
It means there is NO PROCEDURE in the factory service manual for changing the fluid at all. If your dealer says they can change the fluid, they are lying. They can't. They can drain a small amount of fluid and replace it. That' ALL they can do.
If they tell you they'll hook up their machine and do a transfusion through the lines running to the cooler, they MIGHT be able to accomplish this, but they'll still have to deal with setting the level correctly which means they'll need to let the transmission cool so they can get the fluid to the right temperature to set the level. And yes, they will charge a small fortune for this because WS fluid is not at all cheap and they'll have to completely flush their machine of all Dexron before they do this.
shroomysou
31
12-24-19 04:04 AM
