HELP! I think I blew up my DRL/High beam fuse!
Old 08-18-09, 03:55 PM
anson89
anson89's Avatar
Default HELP! I think I blew up my DRL/High beam fuse!
I tried installing the DRL LED upgrade from VLEDS and this is what happened. I only connected one on the driver side and left the passenger side untouched. I started the car, it lit up for like 2 seconds and then it goes off. Did the fuse or something blew up? Because now both DRLs (upgrade and stock) aren't working. Plugged in the bulb to the wiring with the yellow band, module's wire to the stock wire. Turned on all lights, high beam, drove around, restarted the car a few times, still nothing.
I contacted V-LEDS and they told me to test it with OEM, a different aftermarket 9005 bulb, test the DRL upgrade bulb without the relay. If it doesn't work, maybe the highbeam fuse was blown at the engine compartment. Any idea how I can fix this because I'm a total noob at this thing.
Take it to Lexus? I changed out my intake and parking lights. That means the warranty is voided? I can change out all my parking lights and DRL to OEM, but the intake is gonna be a b****h.
Old 08-18-09, 05:13 PM
Evil Teo
Evil Teo's Avatar
calm down anson89. just put everything back to stock and leave the intake. the intake should not cause any damage to electrical stuff so it shouldn't void ur warranty unless they can prove it did which is pretty stupid if they did try. put the lights back to stock and take her in to the dealer. if its just a fuse u shouldn't worry that much.
Old 08-21-09, 12:50 PM
anson89
anson89's Avatar
So I went to the dealership today, once again, a bunch of BS. They found out I have a aftermarket HID kits on the fogs and 8k on the lows. They told me put everything back to stock and they'll diagnose it for $300. For that amount of money, it's just not worth it to fix my DRL/high beams. Any other options? I've tried calling V-LEDs, those guys won't pick up.
Old 08-21-09, 02:17 PM
IS-Fly168
IS-Fly168's Avatar
did you even check the fuse before you went to the dealer? Im pretty sure its just a fuse
Old 08-21-09, 05:07 PM
anson89
anson89's Avatar
I did look through the manual, but I'm not sure which one was it? Is it the same fuse as the horn?
Old 08-22-09, 12:12 AM
anson89
anson89's Avatar
Please help? It's really frustrating to see 98 views, having the dealer throw me a $300 BS fix on my high beams, letting my $120 DRL LED sit in the garage for 2 weeks and not a single solution here.
Old 08-22-09, 01:32 PM
n0th1ng
n0th1ng's Avatar
it should be the interior fuse either under the passenger seat or underhood...
if you look at the fuse after you pull it out, you will see the metal piece blown up and seperated
Edit: i didnt know it was your highbeams. i thought you were talking about interior lights... but still highbeam lights should be in somewhere in the fuse boxes....
Old 08-22-09, 03:58 PM
anson89
anson89's Avatar
Still can't seem to find the right fuse on the manual
Old 08-22-09, 05:34 PM
clifftrail
clifftrail's Avatar
Quit looking in a manual and open the fuse boxes and start pulling til you find it.
Old 08-22-09, 07:04 PM
Evil Teo
Evil Teo's Avatar
wow 120 for ur drl led. that is kind of expensive unless u bought 2 pairs or some other leds along with the drl.
Old 08-23-09, 04:53 PM
anson89
anson89's Avatar
YEAH! TELL ME ABOUT IT! Vleds claim it to be 3x brighter than the original ones, so it's a little more expensive. And this happened... still the same problem. Not even fixed. I'm just gonna give up, unless someone helps me out here.
Old 09-11-09, 07:59 PM
Cali2is
Cali2is's Avatar
Any help here?? Any info on the location of the DRL fuse? I believe it is in a hard to get to location in the engine compartment on the drivers side.
Thanks...
Old 09-11-09, 08:59 PM
ming15237
ming15237's Avatar
Thanks...
So I just saw this post and decided to pull a wiring schematic for the vehicle. It would appear that the fuse for the high beams and the DRL's are NOT listed on the same fuse, wondering if the OP is confusing the two... Anyways, the fuse you are looking for will be in the drivers side of the engine compartment, and "should be" a 15 amp fuses it should be marked "H-LP" , it is possible that it could be a 30 amp fuse but I doubt it, thats a really high number for just high beam lights. Get a pair of needle nose pliers and pull each fuse ONE AT A TIME and look at the fuses until you find one which is burnt in the center area of the fuse, IT WILL BE OBVIOUS when you find it! Just remember 1 fuse at a time, it would be impossible for even a "NOOB" such as yourself to screw that up!
Old 09-11-09, 10:20 PM
Cali2is
Cali2is's Avatar
Thanks... Just found it. It is on the driver's side of the engine compartment, but you have the pull out the controller (it's listed on the underside of the cover). It's a 15 amp fuse, it is marked H-LP, it's the first fuse (top one closest to the driver. The controller is easy to pull out, just pinch the two ends and pull. It's about 1 inch wide and 4 inches long. The controller has about 5 fuses along the top.
Old 09-11-09, 11:09 PM
verals05
verals05's Avatar
is it fixed? I'm eager to see these...
xman
09-29-13 10:01 PM
huyqly
12-20-12 06:04 PM
anson89
IS F (2008-2014)
08-16-09 07:38 PM
qewani1
Lighting
01-02-09 09:50 AM
jpmotdyn
10-27-02 12:58 PM
Quick Reply: HELP! I think I blew up my DRL/High beam fuse!
