Kw v3?
Old 07-31-09, 09:49 PM
MAV3556
MAV3556's Avatar
Default Kw v3?
I've been thinking about changing out my suspension for a more comfortable ride with a some sportiness. KW V3 was something I've been thinking about purchasing, but I've heard some problems with it recently. Horrendous scarping/squeaky noise over bumps and leaking oil.
http://www.e90post.com/forums/showthread.php?t=243156
Does anybody on this forum have KW V3 on their car? How's the ride quality at low speeds on ruff roads? How does it feel compared to stock?
Old 08-01-09, 09:20 AM
UCrazyKid
UCrazyKid's Avatar
Sounds like you already have your answer here "Horrendous scarping/squeaky noise over bumps and leaking oil." If this is true I would certainly stay away and not put these on my car.
Old 08-01-09, 12:27 PM
chrisburke
chrisburke's Avatar
they are great coilovers the downside is that they are not adjustable stroke which when lowered you lose shock travel which could result in shock bottoming out and possible blowout. awesome for the track.
Old 08-01-09, 07:14 PM
CircuitMS
CircuitMS's Avatar
KW makes a nice suspension. They ride well and they have a long stroke compared to most coilovers.
They are definitely not for "slamming" your car though, due to the limited ability for lowering before you eat into the suspension travel.
Old 08-01-09, 08:50 PM
MAV3556
MAV3556's Avatar
CircuitMS, do you know of these problems with the KW V3's for the IS-F? Is the ride quality more smoother than stock? Is it possible to keep ride height the same as stock with the KW V3's?
Old 08-01-09, 09:11 PM
chrisburke
chrisburke's Avatar
i can answer that the height can be put at the same as stock and they ride 100 times better, due to dbl adjustable ( compression and rebound). They are a great setup but the ride will not be as jarring due to the softer spring rates.
Old 08-01-09, 10:05 PM
MAV3556
MAV3556's Avatar
OK, that sounds great that the stock height can be maintained and that the ride won't be a jarring/harsh over pot holes and rough roads. But what about the handling and cornering? will it improve as well or will it become sloppy?, and as for the reliability does anybody have problems?
Old 08-02-09, 05:45 AM
t0e
t0e's Avatar
^^ To Mav ^^
You cant have "One" Without the "Other"
Decreasing the Rebound, Travel or Stiffness should change every aspect of your handling and cornering ability.
I'm sure after numerous hours of trial and error you can tune your suspension to handle well and not be so jarring.
But don't expect this to come out of the box (install and go) fine tuned. You cant have it both way's great handling and soft ride....
Old 08-02-09, 01:13 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
I was looking into these too...
Do they require both oem front & rear top hat transfers??
Joe Z
Old 08-02-09, 04:13 PM
FIGS
The Maker
FIGS's Avatar
I approached them last year and they had no intent on making this application. What is the latest?
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 08-02-09, 04:20 PM
chrisburke
chrisburke's Avatar
JOEZ,
when i checked with kw regarding our set up they told me it required us to transfer out old ones over to there setup. Regardless it will result in a quieter ride.
Old 08-03-09, 08:45 AM
Joe Z
Joe Z's Avatar
Fig
^^ Looks like they released the system for the ISx50 & IS-F
Originally Posted by chrisburke
JOEZ,
^^^ Thanks for the info Chris...!!
Old 08-03-09, 09:10 AM
CircuitMS
CircuitMS's Avatar
They will improve your handling, ride quality is usually a subjective term. They will get rid of the floatiness, which personally I think is an improvement. They should not feel "harsh". They have a nice damping range and rate.
They do re-use the front and rear topmounts. Which is not a bad thing, it will help to keep noise and vibrations to a minimum.
Old 11-03-10, 06:16 AM
weaponX
weaponX's Avatar
3 weeks to order from Deutschland.
I hope they're worth the wait.
Anybody have suggestions for settings for a good combination of ride/handling?
Old 11-03-10, 10:28 AM
T-Rex06
Ho Motorsports
T-Rex06's Avatar
You'll be happy with your purchase. These coils have independent adjustments for compression and rebound. Keep it to the factory recommended settings and see if that works for you. For me, factory settings work perfectly.
The adjustments are different from typical coilovers. The compression adjustments are located at the bottom of the shock assembly and the rebound is at the top.
Terrance
Quick Reply: Kw v3?
