Lsd
Old 07-08-09, 09:06 AM
LEXUSF
LEXUSF's Avatar
Default Lsd
Is anyone selling a LSD for the IS-F? If so or if not what would the real gains be for the car? thanks!
Old 07-08-09, 10:38 AM
UCrazyKid
UCrazyKid's Avatar
The gains would be the same as adding a LSD to any other car or less since the IS-F already uses an electronic LSD. Unless you are tracking the car or doing autocross and want to shave seconds off of your lap time, do not even bother.
Old 07-08-09, 12:20 PM
rominl
exclusive matchup
rominl's Avatar
agree, unless you push your car to the limit on track, or you always want to see two-wheels burnout, lsd won't give you much gain on normal driving
Old 07-08-09, 01:55 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,835 Likes on 2,324 Posts
Lexus will have one on the 2010 model. I plan to retrofit one to my F.
Old 07-09-09, 07:22 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
So, just for giggles I decided to find out if it is possible to do a direct swap with a MkIV Supra 6 speed diff and the IS-F. Sadly the Supra diff (with the Torsen unit) is about 25mm longer than the unit in the F. This might be why Supra owners going from auto to 6 speed needed the diff and driveshaft to make the conversion truly complete. The autos came with an open diff, the 6 speeds came with the Torsen LSD.
So, unless there is some internal magic, we'll still have to wait for the 2010 units to show up. It would really get expensive if it's a diff, driveshaft, and skid control ECU swap. Those three pieces will be pretty pricey.
Old 07-10-11, 04:57 PM
CCJ22
CCJ22's Avatar
I always thought that the LSD is great for DDing in the rain?
willstroo
IS F (2008-2014)
84
02-07-22 07:38 PM
wootw00t
06-28-13 03:04 PM
lex400sc
Performance & Maintenance
10-28-04 03:13 PM
Quick Reply: Lsd
