TSW Indy 500's No Worky On IS-F!!!
Old 04-17-09, 07:57 AM
TinCan
TinCan's Avatar
So can I fit a 19x10.5 in the rear? I see people putting 305's under these cars, but little info on the rim sizes themself, I don't see a 305 fitting on a 19x9.5 rim. Thank for the help
Old 04-17-09, 08:27 PM
CrazyMPG
Phat Monkey
CrazyMPG's Avatar
you can fit 305's only if you have wider fenders...I ran 295/30/19 Michelin PS2's b4 on my IS-F with stock suspension on my HREs...but they rubbed...so the fenders were shaved...heh
Old 04-18-09, 08:04 AM
TinCan
TinCan's Avatar
Thanks for the info, so looks like I'm staying with the 285's I have no plans to change the suspension.
Old 04-18-09, 08:37 AM
TinCan
TinCan's Avatar
Okay, I have one more question, I'm going to a different 5 axis rim.... an S6:F Spec. Before I spend this money.... I want to make sure that the sizes are going to work with the ISF.These are 100% custom so I can make them any size I need. 19x8-19x8.5 with a 40mm offset in the front, and 19x9.5-19x10 with a 35mm offset in the rear. From what I've searched I found the 35mm to work in the rear and not rub the outer fender and not smack the brakes. Thanks
Old 04-18-09, 10:31 AM
primecut
primecut's Avatar
If these are 100% custom, then you should have 5axis give you the recommendation. You should be able to tell them what kind of fitment you want (aggressive, conservative, etc.), and they would build you a set that will fit and look perfect. There's no way for you to sort this out on your own, since each wheel is different, and there's no telling that a specific numerical setup would work across all wheels.
Old 04-19-09, 07:48 PM
I8ABMR
I8ABMR's Avatar
I think the TSW wheels you chose would look better on a TL. If they dont fit I would return them
Old 04-20-09, 08:32 AM
TinCan
TinCan's Avatar
I had these on my 350 before I got the F
Old 05-04-09, 08:49 PM
Stefwilli
Wheel Vendor
Stefwilli's Avatar
Check out the Forgestar line we carry, light weight, nice styles, great price.
http://www.d2autosport.com/D2_2006/0..._forgestar.htm
Old 05-04-09, 09:24 PM
Mar48
Mar48's Avatar
get some high end wheels if you are going to put wheels on your F... TSWs as stated just don't cut it
Old 05-04-09, 09:54 PM
LexFather
Guest
Posts: n/a
The IS-F came with BBS wheels, some of the best wheels around. BBS is regarded by some as the best brand. Why go to TSWs or even Axxis? That is like 4 steps down.
Old 05-04-09, 10:08 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Lightbulb
Here I just finished swaping the hood, bumper, fenders & side skirts....
S5:F - Five Axis Gunmetal Matte Wheels installed.
(photo courtesy of "WiLz")
Joe Z
Old 05-04-09, 11:40 PM
TinCan
TinCan's Avatar
Thank you so much for the pic!! What sizes and offsets are those, and tire sizes too? Thanks again
Old 05-05-09, 03:25 AM
montgb
montgb's Avatar
Joe Z
I don't mean to thread-jack, but you did what?!?! Usually I'm against swapping body panels to make a car look like a better model, but I'm torn because the install looks really good. How did everything fit?
Old 05-05-09, 06:07 AM
Juanca
Juanca's Avatar
LOL... that was exactly my reaction! Man, if I'm not reading Joe's post I'd think that's a real IS-F. Well done Joe.
Old 05-05-09, 07:43 AM
javyLSU
2IS OG
javyLSU's Avatar
Wait until you guys see the engine and transmission swap we've been working on...
Javier
Quick Reply: TSW Indy 500's No Worky On IS-F!!!
