clutch smell
clutch smell
i have been driving with VSD off and sports mode in auto for the last weeks. when i floored the gas and making a sharp turn, i could hear something spinning and followed by a nasty smell that resembles burned clutch. i though maybe my tires were spinning, but i dont hear any squeals. i know this car does not have a clutch, but is it possible the transmission is slipping and caused the smell?
Tech Info Resource
More than likely tires. Our electronic LSD doesn't work at low speeds or from a stop like a mechanical LSD, so you can spin a tire pretty easily.
Are you serious that the LSD is inop at low speeds or from a stop? What good is that if you can't launch the car from a standing start without applying the power to both wheels?
Lexus Connoisseur
What he means is, the "electronic LSD" is not a mechanical feature. Basically the LSD like feature is operated electronically by a combination of ABS/TRAC/VSC.
Tech Info Resource
and it does not work from a stop or at very low speeds. If you want to mimic a mechanical LSD, you'll need to put the parking brake on a couple of clicks.
Lexus Connoisseur
Now that I think about it, if you're smelling a clutch like smell, it's most likely your brakes after you're hard on them.
i did not touch the brake paddle at all each of the three times i smelled the "clutch." all three times occurred when i was at stop sign or stop light and stepped on the gas hard off the line. it only happened when i was hard on gas and making a hard turn at the same time, so that makes buring rubber likely. i thought it smelled more like burned clutch than rubber though.
my car also makes a wierd smell like a burning clutch when i go WOT. It happens even when i am not going from a stop. I try to pinpoint where the smell is coming from but i cant. Should i take this into the dealer or will they even do anything. The car runs great.
