Radiator Options
Radiator Options
Had my car in the dealership fixing a chewed wiring harness, they found my radiator was leaking.
After researching only thing I found was a is300 that needs modifying. Is there a Koyo or Mishimoto radiator replacement for the ISF that I'm not seeing?
Also where is a good place to buy an OEM radiator without getting bent over? Found some on the web that states OEM but not too sure if it's legit OEM or OEM comparable.
Koyo racing only has aluminum for IS300 . Mishimoto doesn't either . JustinD here on forums was retrofitting a Mishimoto to his F. I've helped replace 3 ISF radiators. ICODE makes a aluminum radiator for the F but it's over 1k for the part. For OEM they run 335-360. Mylparts.com vendor here has a 10 percent off CL5 code. Or I get my oem at houseoflexus.com.
The Maker
We started down the development path and have production ready to go, we just need a gauge of interest before investing in the large run. We can add slightly more capacity and increase efficiency. Pricing would be in line with the OE, around $700. We can also modify other radiator applications in house if there is not sufficient demand. We had originally tackled this as an alternative to an oil cooler solution, but at the moment our oil cooler performed so well, even reducing coolant temps, that we shelved the project to develop other things.
Contact us for interest and we will make it happen.
Mike
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
I sent a PM to the one guy who mentioned retro fitting the Mishimoto IS300 all aluminum radiator, but no response. I settled and went and ordered an OEM from Park Place Lexus in Grapevine.
From my understanding, I would basically need: 1.4" to 1.5" hoses for both the in and outlets, custom fan shroud while reusing original fans, custom top mount brackets, and a remote transmission oil cooler. The overall height and width are pretty close and the inlet/outlet are in the same general vicinity. The possibility of having an all aluminum radiator is quite tempting. Unfortunately, email replies from Mishimoto were of them telling me not to and to go forward with one that was specifically designed for an IS-F.
If this radiator craps out, then I'll probably just go with the retrofit and cut up the shroud myself.
Also I placed an order for new HPS blue radiator hoses from Figs a couple days ago and the order is still pending. :-/
The Maker
Mike
__________________
Mike
Mike
I would be willing to shell out $700
