Anyone put Stock mufflers on a Borla system?
Just wondering if anyone has tried putting the stock mufflers on to a Borla cat-back system?
May be best of both, keep the gains, ditch the drone...?
Not Borla but here yea go.
https://www.clublexus.com/forums/is-...-mufflers.html
https://www.clublexus.com/forums/is-f-2008-2014/618225-my-new-rear-section-exhaust.html
https://www.clublexus.com/forums/is-f-2008-2014/602047-this-is-how-i-got-rid-of-the-drone-on-my-joe-z-exhuast.html
Was thinking of doing the same thing to my Borla with PPE headers setup (= too loud/drone). I bought 2 additional resonators off of Amazon and when I got to the muffler shop there wasn't anywhere to fit them in the back, and we looked for about 25 min trying to find a spot to weld them on and no dice
So my next option is to weld on the stock mufflers to the Borla????? I can't imagine losing that much power just with the stock mufflers considering the whole system is open all the way back to that point?
Since the Borla gets rid of the 2nd cats, and that crushed Y splitter piece, I would assume the Borla pipes with stock mufflers would still keep some of the gains. But it's speculation at this point.
anyone know the size of the pipes right before the mufflers on the stock system?
Would be nice if I could just measure and cut the stock mufflers off the stock system, and install them on the 2.5" Borla pipes at the clamps after the rear axle
Because the stock mufflers are well designed as Lou's pic showed when they cut his open, the characteristic that I'm going for is the destructive interference that it would provide to cancel out the drone of the straight through design of the Borla mufflers.
I'm still debating whether to do this or not
More or less what I was thinking of ^^^^....... only mine would literally be cut off enough to just have room to weld to the Borla piping to keep the 2.5" diameter and flow characteristics of the Borla just with the stock mufflers.
...Just need to know stock pipe size right at the mufflers...
If you don't mind losing some of the overall volume of the exhaust along with losing the drone, quarter wave resonators (aka side branch resonators) will kill the drone and will add zero restriction to the exhaust. I did this with my Tacoma and it worked beautifully.
A bit of reading on the subject (Google will give you a whole lot more):
http://forums.corral.net/forums/gene...tely-gone.html
I'm looking into this option for my F currently:
https://www.clublexus.com/forums/is-...enix-area.html
if the stock pipe size is like 2-1/4" then if a guy was to get the right size adaptor and clamps, this could be done with no Welding required, making it completely reversible with no mods to the Borla components.
I'll do some research as well and see what I find
so I may try this
